Giriş
Use this guide to replace a damaged microphone.
Neye ihtiyacın var
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
Use the tip of a spudger to pry the microphone away from the side of the upper case.
Remove the microphone from the upper case.
Bir başkası bu kılavuzu tamamladı.
