Giriş
Use this guide to replace a noisy or nonfunctional fan.
Neye ihtiyacın var
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
25 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
I think my fan makes some noises when my laptop is cold in the morning... Cold means 18°C... Is it dangerous?
After a few minutes or even seconds, the sound stops.
I’m a 21 y/o college student whose laptop fan was being too loud to use in class and I decided to take matters into my own hands so I took the risk of completing these replacement instructions and I’m so glad I did! My laptop fan no longer makes noise and I didn’t have to take it to Apple and have them overcharge me for something simple enough for me to do at home. Thank you!!
