Ana içeriğe geç
MacBook Air 11" Mid 2013 I/O Board Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: adım 1, 3 resimden 1. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: adım 1, 3 resimden 2. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: adım 1, 3 resimden 3.
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  2. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 2, 2 resimden 1. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  3. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 3, 3 resimden 1. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 3, 3 resimden 2. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 3, 3 resimden 3.
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  4. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 4, 3 resimden 1. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 4, 3 resimden 2. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 4, 3 resimden 3.
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  5. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 5, 1 resimden 1.
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  6. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 6, 3 resimden 1. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 6, 3 resimden 2. MacBook Air 11" Mid 2013 I/O Board Replacement: adım 6, 3 resimden 3.
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Sonuç
Sam Goldheart
471.983 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 127
