Ana içeriğe geç
MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement
Neye ihtiyacın var
  1. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the screws securing the lower case: adım 1, 1 resimden 1.
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the lower case: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Disconnect the battery: adım 3, 1 resimden 1.
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 4, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 4, 2 resimden 2.
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the right speaker adhesive: adım 5, 3 resimden 1. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the right speaker adhesive: adım 5, 3 resimden 2. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the right speaker adhesive: adım 5, 3 resimden 3.
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • If the adhesive strip breaks, leave it in and proceed to the next step.
  6. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 6, 2 resimden 1. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 6, 2 resimden 2.
    • Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker.
  7. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 7, 3 resimden 1. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 7, 3 resimden 2. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement: adım 7, 3 resimden 3.
    • Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers.
    • If the adhesive strip breaks, or if the first adhesive strip broke, use a heated iOpener or heat gun to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement, Remove the right speaker: adım 8, 1 resimden 1.
    • Lift the right speaker straight up from the bottom and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam O'Camb
196.194 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,617
