Giriş
Use this guide to replace the AirPort/Bluetooth card.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
24 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
