Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99-
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
Remove the AirPort/Bluetooth card from the Air.
27 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
I'm getting a "Wifi: No hardware installed" with an X over the wifi icon in the Menu.
Even after I swapped the original Airport card with a second one. Neither one works. The original worked up until a short time ago. I hadn't used the Air for a few months, but when I started it up the Airport wasn't recognized.
Also, should mention that Bluetooth works fine.
Could it be the Airport cables?
Specs: 13" Air (2014) running Mojave 10.14.1
I use a Netgear router with a Macbook Air 13, and the internet is very slow with it, and the connection is always disconnected and back on.
