Giriş
Use this guide to replace the right-hand speaker in your MacBook Air 13" Early 2015. This guide shows you how to replace the speaker that is on the right during normal operation, but during the guide it will often be on the left side. Be sure you are replacing the correct speaker, and have the correct part.
Neye ihtiyacın var
Bu adımda kullanılan alet:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Remove the following five screws securing the battery to the upper case:
Three 6.9 mm T5 Torx screws
Two 3.0 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
7 farklı kişi bu kılavuzu tamamladı.
