Ana içeriğe geç
MacBook Air 13" Late 2020 Audio Board Replacement
Neye ihtiyacın var
  1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the screws securing the lower case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: adım 2, 3 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: adım 2, 3 resimden 2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the lower case: adım 2, 3 resimden 3.
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: adım 3, 3 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: adım 3, 3 resimden 2. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the battery: adım 3, 3 resimden 3.
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board connector cover: adım 4, 1 resimden 1.
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Audio Board Replacement: adım 5, 1 resimden 1.
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: adım 6, 3 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: adım 6, 3 resimden 2. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the speaker: adım 6, 3 resimden 3.
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
  7. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: adım 7, 3 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: adım 7, 3 resimden 2. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the Touch ID cable: adım 7, 3 resimden 3.
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  8. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: adım 8, 2 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Disconnect the audio board cable: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board screws: adım 9, 1 resimden 1.
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
  10. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: adım 10, 3 resimden 1. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: adım 10, 3 resimden 2. MacBook Air 13" Late 2020 Audio Board Replacement, Remove the audio board: adım 10, 3 resimden 3.
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
Sonuç
Once you've completed your repair, your laptop may not power back on until connected to power.
8 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
112.684 İtibar
338 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.731 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 91
Son 30 gün: 334
Her zaman: 7,884
