Ana içeriğe geç
MacBook Air 13" Mid 2013 Fan Replacement
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Mid 2013 Fan Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Mid 2013 Fan Replacement, Battery Connector: adım 3, 2 resimden 1. MacBook Air 13" Mid 2013 Fan Replacement, Battery Connector: adım 3, 2 resimden 2.
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Mid 2013 Fan Replacement, I/O Board Cable: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  4. MacBook Air 13" Mid 2013 Fan Replacement: adım 5, 1 resimden 1.
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  5. MacBook Air 13" Mid 2013 Fan Replacement: adım 6, 2 resimden 1. MacBook Air 13" Mid 2013 Fan Replacement: adım 6, 2 resimden 2.
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  6. MacBook Air 13" Mid 2013 Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  7. MacBook Air 13" Mid 2013 Fan Replacement: adım 8, 1 resimden 1.
    • Peel the rubber gasket off the adhesive on the top of the fan.
  8. MacBook Air 13" Mid 2013 Fan Replacement: adım 9, 1 resimden 1.
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  9. MacBook Air 13" Mid 2013 Fan Replacement: adım 10, 2 resimden 1. MacBook Air 13" Mid 2013 Fan Replacement: adım 10, 2 resimden 2.
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
3 Comments
Step 1
My mid-2013 MacBook Air requires a pentalobe P4 driver, not a pentalobe P5 driver. I got a set of P1 - P6 so it wasn't an issue for me.
Scott - Yanıt
Do I need the artic silver thermal paste? I know the guide does not mention it, but a repair guy I went to first included it in the quote they gave me to fix the fan ($200 for parts and work for a fan replacement)
Mary Austin Morgan - Yanıt
Arctic silver is a great thermal paste, but in my experience the swapping of the fans does not require any thermal paste. Thermal paste is usually used in between the connections of the computer's processor heat sink(s) and the processor, as well as the graphics card and the heat sinks.
Barrythetech -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 24
Son 30 gün: 103
Her zaman: 24,514
