Ana içeriğe geç
MacBook Air 13" Retina Display 2020 Smaller Keys Replacement
Neye ihtiyacın var
  1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement, Smaller Keys: adım 1, 1 resimden 1.
    • Clean the keyboard.
  2. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 2, 2 resimden 1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 2, 2 resimden 2.
    • Gather all necessary pieces that may have come off with the key.
    • The key itself.
    • The hinge piece.
    • Orient the hinge piece in the proper position.
  3. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 3, 3 resimden 1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 3, 3 resimden 2. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 3, 3 resimden 3.
    • Install onto single mount first.
    • Then press into the double mount.
    • Make sure the hinge is in place properly, or the key will not stay on.
  4. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 4, 1 resimden 1.
    • This piece, the rubber cap, doesn't come off often. But if it does, you can reinstall it by pressing down on the middle.
  5. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 5, 2 resimden 1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 5, 2 resimden 2.
    • Orient the key in the proper position.
  6. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: adım 6, 1 resimden 1.
    • Press the key down into place.
Sonuç
To disassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Is this strictly for the early 2020 MacBook Air, or will this same technique work for the late 2020 MacBook Air?
iannai29 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 88
Son 30 gün: 654
Her zaman: 12,069
