Ana içeriğe geç
Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 1, 1 resimden 1.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    I used this guide plus the Thermal Paste guide to resolve my MacBook RRS (Random Restart Syndrome) issue. My MacBook would randomly restart after the fan kicked into high speed. When I removed the heatsink I discovered an an irregular patch completely free of thermal compound of about 15-20% of the area on one of the processors. I removed and re-applied the thermal paste. I ran a memory test utility overnight that previously caused a restart after a couple of hours, and the probelm seems to be solved. TIme will tell.
    ServiceDocs - Yanıt
    This guide was seriously helpful, so thanks for putting this together. I found a thick ribbon of dust/muck whatever between the fan outlet and the exhaust port that was almost as dense as felt. My fan must have been fighting like crazy trying to pass air through that blockage, which explains the high temps and excessive fan noise. Wish I'd done this sooner...
    Thanks again!
    skraggle - Yanıt
    Just R&R'ed the fan in my black MacBook Core 2 Duo tonight. Took me 30 minutes tops and I was taking my time. These instructions are SPOT ON! Great job ifixit.com! Two thumbs up!
    Follow the instructions exactly as you see and have a piece of paper taped to the table next to you that you can outline all the screws you took out so you know where they go back in. I expected this to be a LOT harder, but it was one of the simplest repairs I've ever done to ANY computer!
    mikeutter - Yanıt
    Piece of cake--or should I say gum. If you don't have a magnetized screwdriver, load up a stick of gum and chomp on it until it's needed then use a bit to retain screw on the driver. And if you should tear the black tape, or if the silver tape won't stick any more, just bubblegum it together. The instructions were clear and correct, which made for a very simple repair.
    Mike Woodruff - Yanıt
    My battery does not pop out when after step 1. Any idea why, and how do fix it?
    Calvin - Yanıt
    Calvin kullanıcısından alıntı:
    Will not drop out even if you turn it upside down?
    skraggle - Yanıt
    Somehow, now my isight camera doesn't work and the light is always on. Cannot figure out what I did wrong.
    josefsalyer - Yanıt
    Somehow the plastic disc with the slot for a coin got dislodged from the case, and I can't seem to get it open now. Any tips/links on how to open this without the aid of the plastic disc?
    Peter Wood - Yanıt
    i broke my disc off as well. I used two toothpicks to rotate the thing. hi tech.
    howard bederman -
    Outstanding guide - thank you!
    owen bullock - Yanıt
    My computer will not charge when plugged in. It will stay on as ling as the plug is in the wall however if the power source gets disconnected it will shut down immediately. I removed the battery and put it back in that did not help. It worked and charged fine 2 days ago. I have a backpack with a laptop storage area. I went to hang the backpack up and it fell and ever since the battery is not functioning. Is there some fix I can try or is my only solution to replace it? I would have thought that dropping it would affect more than the battery?
    Beth Tomasek - Yanıt
    Better leave the back pack where it cannot fall. Hindsight is so much better than foresight . I learned the hard way too!
    Loy Lum - Yanıt
    Many of the tiny screws in this project were quite sticky. I found some blue Loctite residue that must have been when the Apple repair shop worked on the laptop years ago. I have found that it is important to hold the correct driver firmly down in the screw and then just tweak the driver in short bursts to loosen it before unscrewing it with a smooth turn.
    Patrick Langvardt - Yanıt
    Be really careful while doing this to not use too much force while doing this step, because the plastic disc can break off and it can be a cosmetic issue along with functionality issue. This happened to me first hand so please take my word for it…
    [deleted] - Yanıt
    Probably worth mentioning at this stage that the caddy you propose to use should not have lugs on the front corners, like those used in unibody 1278 and onwards.
    harwood - Yanıt
    Hehe, still my mac os running! After, already bit more than 10 years of use!
    I put new heat paste now for the second time. Maybe this helped for staying young so long.
    Thanx for all the repair guides!!!
    Fabien - Yanıt
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 2, 1 resimden 1.
    • Lift the battery out of the computer.
    I just replaced the battery as indicated (with a iFixit part), but the computer says there is no battery connected, even after letting the power plug in for more than one hour.
    Jean Wallemacq - Yanıt
    I think I found the way to have the new battery to charge!!!!!
    See: https://www.youtube.com/watch?v=jRYIMDQx....
    Essentially, you have to follow a very precise order: 1/shut down the computer, 2/take off the magsafe connector, 3/remove the old battery, 4/put back the magsafe connector, 5/put the new battery, 6/power on, each time leaving a few seconds in between.
Bitiş Çizgisi
158 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
4 Yorum
Lors de mon voyage aux USA, j’ai ramené des pièces 1/4 $… Juste pour le plaisir de changer ma batterie.
Ludovic - Yanıt
so now it shows charged, charges the battery but refuses to run off the battery
mike.collepardi - Yanıt
It is still not working, the battery is stuck.
ftslr mantooth - Yanıt
My macbook doesn't look like that on the bottom. 13" mid 2010 2.4GHz Intel Core 2 duo. Only screws.
Query - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 129
Her zaman: 88,342
