Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
  1. Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    I used this guide plus the Thermal Paste guide to resolve my MacBook RRS (Random Restart Syndrome) issue. My MacBook would randomly restart after the fan kicked into high speed. When I removed the heatsink I discovered an an irregular patch completely free of thermal compound of about 15-20% of the area on one of the processors. I removed and re-applied the thermal paste. I ran a memory test utility overnight that previously caused a restart after a couple of hours, and the probelm seems to be solved. TIme will tell.
    ServiceDocs - Yanıt
    This guide was seriously helpful, so thanks for putting this together. I found a thick ribbon of dust/muck whatever between the fan outlet and the exhaust port that was almost as dense as felt. My fan must have been fighting like crazy trying to pass air through that blockage, which explains the high temps and excessive fan noise. Wish I'd done this sooner...
    Thanks again!
    skraggle - Yanıt
    Just R&R'ed the fan in my black MacBook Core 2 Duo tonight. Took me 30 minutes tops and I was taking my time. These instructions are SPOT ON! Great job ifixit.com! Two thumbs up!
    Follow the instructions exactly as you see and have a piece of paper taped to the table next to you that you can outline all the screws you took out so you know where they go back in. I expected this to be a LOT harder, but it was one of the simplest repairs I've ever done to ANY computer!
    mikeutter - Yanıt
    Piece of cake--or should I say gum. If you don't have a magnetized screwdriver, load up a stick of gum and chomp on it until it's needed then use a bit to retain screw on the driver. And if you should tear the black tape, or if the silver tape won't stick any more, just bubblegum it together. The instructions were clear and correct, which made for a very simple repair.
    Mike Woodruff - Yanıt
    My battery does not pop out when after step 1. Any idea why, and how do fix it?
    Calvin - Yanıt
    Calvin kullanıcısından alıntı:
    Will not drop out even if you turn it upside down?
    skraggle - Yanıt
    Somehow, now my isight camera doesn't work and the light is always on. Cannot figure out what I did wrong.
    josefsalyer - Yanıt
    Somehow the plastic disc with the slot for a coin got dislodged from the case, and I can't seem to get it open now. Any tips/links on how to open this without the aid of the plastic disc?
    Peter Wood - Yanıt
    i broke my disc off as well. I used two toothpicks to rotate the thing. hi tech.
    howard bederman -
    Outstanding guide - thank you!
    owen bullock - Yanıt
    My computer will not charge when plugged in. It will stay on as ling as the plug is in the wall however if the power source gets disconnected it will shut down immediately. I removed the battery and put it back in that did not help. It worked and charged fine 2 days ago. I have a backpack with a laptop storage area. I went to hang the backpack up and it fell and ever since the battery is not functioning. Is there some fix I can try or is my only solution to replace it? I would have thought that dropping it would affect more than the battery?
    Beth Tomasek - Yanıt
    Better leave the back pack where it cannot fall. Hindsight is so much better than foresight . I learned the hard way too!
    Loy Lum - Yanıt
    Many of the tiny screws in this project were quite sticky. I found some blue Loctite residue that must have been when the Apple repair shop worked on the laptop years ago. I have found that it is important to hold the correct driver firmly down in the screw and then just tweak the driver in short bursts to loosen it before unscrewing it with a smooth turn.
    Patrick Langvardt - Yanıt
    Be really careful while doing this to not use too much force while doing this step, because the plastic disc can break off and it can be a cosmetic issue along with functionality issue. This happened to me first hand so please take my word for it…
    Aaron Cooke - Yanıt
    Probably worth mentioning at this stage that the caddy you propose to use should not have lugs on the front corners, like those used in unibody 1278 and onwards.
    harwood - Yanıt
    Hehe, still my mac os running! After, already bit more than 10 years of use!
    I put new heat paste now for the second time. Maybe this helped for staying young so long.
    Thanx for all the repair guides!!!
    Fabien - Yanıt
  2. Lift the battery out of the computer.
    • Lift the battery out of the computer.
    I just replaced the battery as indicated (with a iFixit part), but the computer says there is no battery connected, even after letting the power plug in for more than one hour.
    Jean Wallemacq - Yanıt
    I think I found the way to have the new battery to charge!!!!!
    See: https://www.youtube.com/watch?v=jRYIMDQx....
    Essentially, you have to follow a very precise order: 1/shut down the computer, 2/take off the magsafe connector, 3/remove the old battery, 4/put back the magsafe connector, 5/put the new battery, 6/power on, each time leaving a few seconds in between.
  3. Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    please pay attention that screws are native to metal pieces otherwise you are going to be a stupid like me trying to unscrew unsuccessfully until I reread the guide
    manochu - Yanıt
    Lay the screws out in a ”timeline” like a circle, Then when you reassemble just start from the end of the “timeline”
    decristoforo - Yanıt
    The screws have to unscrewing positions, first they unscrew from the whole body BUT if you move the lid without entirely removing the screws, they will remain attached to the lid. This I find much more recomendable!
    Wytchkraft - Yanıt
    I found when putting this back in that I had to use a spudger to work the mesh/foam into the slot where the memory cards are so the bracket would lay flat again when screwed back in.
    slwatts2 - Yanıt
    What size screwdriver
    edward greene - Yanıt
  4. Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
    • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
    That looks so easy!
    caiden rutledge - Yanıt
  5. Remove the following 3 screws:
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
    I couldn't get the top two 11mm screws to come out, even with a magnetized driver. When I tried to keep unscrewing them, they clicked like they were spring mounted, and I didn't have any trouble leaving them in and continuing on.
    ryan64 - Yanıt
    ryan64 kullanıcısından alıntı:
    I use a strong magnet to pull the screws out of their socket.
    Alaerus - Yanıt
    The top two screws didn't seem to want to come out, and I saw no reason they had to, so I left them there, put a little piece of tape over each so they wouldn't fall out.
    HandyMac - Yanıt
    You need to replace the shorter middle screw first, otherwise it won't tighten later since it won't quite reach the bottom.
    colmcostelloe - Yanıt
    for me this was the hardest part especially the two 14.5mm that dint want to come out. keep turning the screw and slightly pressing the case down, once the screw is a little use try using finger, screw and a non metallic point to try to push them out. they arent tight but they are very hard to unscrew i almost gave up, but believe me they come out with patience
    manochu - Yanıt
    I also did not find that I needed to remove the two 14.5 mm screws. I unscrewed them but they seemed designed to stay with the case and I found it did not seem to affect anything to just let them stay there.
    Alice - Yanıt
  6. Take extra caution with these screws as they can strip easily!
    • Take extra caution with these screws as they can strip easily!
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
    On this step, I encountered a problem. The middle screw was screwed in very very tightly. As a result, I ended up stripping the screw despite being very careful. I tried to use a wire cutter to remove the screw, but that did not work. I actually ended up using the wirecutter to cut the bracket off, leaving the screw screwed in. This did not affect anything. I am typing off of my replace macbook top case right now.
    The point is, BE CAREFUL! but if something does go wrong, don't fret. There are solutions.
    LaNoobieFixer - Yanıt
    On a Macbook I just tore down, I found that in this step, the 4mm screw was on the left, not the right. I thought maybe someone else had it apart before and accidentally switched them so in staying true to these instructions I tried to reassemble with the 4mm screw on the right. I found it would not go all the way in. I ended up putting it back together with the 2-3mm screws on the right and the 1-4mm screw on the left.
    scottgriz - Yanıt
    I didn't look closely at these screws when I took it apart, but when I went to put it back together (two weeks later) I found I had two longer (4mm?) screws, and one short one. So I put the longer ones in the two end spots, the short one in the middle; they all seemed to go in okay. (Maybe the screws got changed around the last time the cracked top case was replaced, when the MB was in the Apple shop under warranty last year.)
    HandyMac - Yanıt
    Me too. I had two longer 4mm screws here, and one 3mm screw. And I didn't pay attention to what holes each screw came out of. I put them back in a random order and it seems fine.
    Thomas -
    My early 2008 MacBook was the same. 2 x 4mm in the outer and 1 x 3mm in the centre.
    Ernie K -
    You need to replace the shorter middle screw first, otherwise it won't tighten later.
    I needed a tweezers here. These screws are tiny!
    If you lose one you may have to remove the RAM (by pulling the appropriate lever) and gently slide out the screw.
    oh thanks I thought the screw was lost forever
    Ike Broflovski -
    I couldn't pull over the two 3 mm Phillips on the step 6, how could you've done it?
    Eliotus - Yanıt
    To confirm what HandyMac and colmcostelloe found, some MacBooks have one 3mm and two 4mm screws in the rear wall of the battery compartment. On the one I worked on, the shorter 3mm screw came from the middle hole.
    BeatJunkie - Yanıt
    please note the position of the screws because when you are reinstalling them you might get confuse. this ones go below or under (sorry English inst my first language). There are two screw holes this steps are for the ones below.
    manochu - Yanıt
    BeatJunkie kullanıcısından alıntı:
    Thanks Beat Junkie, this was the situation with my Mac 2.13ghz Mid 2009 that I was putting back together. Thanks for the confirmation! (For the 6th step)
    Cong Trieu - Yanıt
    For me (A1181), there were two shorter screws and one longer. The longer went on the left (a shorter screw wouldn't catch). (Not the middle that is currently in the instruction. But that could be model difference.) The middle screw started to strip the head but using a slightly larger phillips allowed me to get it out.
    Paul Collins - Yanıt
    I have two MacBooks, one white and one black and both had two 3mm screws and one 4mm screw, opposite of what was in the main document
    doublel - Yanıt
    In my late 2006 macbook the central screw was longer than the side screws..
    Julien Lesage - Yanıt
    Mine was A1181 model, Core 2 Duo 2.16 GHz. Of course I did not keep track of the screws and ended up with two shorter ones and one longer. Replaced them with the longer one to the right of the three. Got it done with a Wiha PH00 screwdriver. Had better hold than the bit from the precision screwdriver kit.
    quentinlow - Yanıt
    me too. Got it done with a iFixIt PH00 screwdriver.
    Johhnie Doe -
    Yeah, same for me, #00 worked; #0 suggested in the guide was too big. I didn’t even try #000. For 2.2GHz A1181. My screw config matched the guide, 3mm in middle, 4mm on the sides.
    Les Kitchen -
    Stripped a head on my left screw (A1181 model, Core 2 Duo 2.0 GHz). Used a precision 1.5 slotted screwdriver to get enough bite to screw it out and back in.
    Daniel - Yanıt
    I couldn't get the suggested Phillips #0 tip to grab. PH#00 worked, but I found the PH#000 to work the best.
    steveeb33 - Yanıt
    I found this step to be the hardest to put back because of the angle - even with iFixIt's driver Flex Extension.
    steveeb33 - Yanıt
    I had two 3mm screws and one 4mm screw…. So I put the 4mm screw in the middle hole, and the 3mm screws in the outer holes.
    FixWiki - Yanıt
  7. Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
    The steps do not tell you what length screw that is needed to be here. What I can tell you that is the screw needs to be 5mm or 6mm, NOT 7.5 or 8mm or 9mm.
    Cong Trieu - Yanıt
    Screwdriver PH0
    Projectors Band - Yanıt
    For black 2.2GHz A1181, I used PH #000 as suggested by guide. My screws are both 6mm.
    Les Kitchen - Yanıt
    Be proud of the fact that you have the ability to rise above any situation and deliver the best no matter what the circumstances could be. ++https://smartdesignmart.com/++ Excellent article! Thank you for your tremendous efforts in this wonderful piece of work.
    dingiridingaley - Yanıt
  8. Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
    It's recommended to use a PH00 screwdriver instead of the PH000.
    The PH000 is too small and you can damage the screwheads.
    Martin Born - Yanıt
    Yeah, I found PH #00 better too. (For black 2.2Ghz A1181.)
    Les Kitchen -
    I used PH0 for this
    Is there a way I can cut the bracket off? I completely stripped one of the screws?
    Austin Martin - Yanıt
  9. Remove the following 4 screws from the back of the computer:
    • Remove the following 4 screws from the back of the computer:
    • The longer screws go on the inside, shorter screws on the outside.
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    Outer screws (red) are shorter (7mm long), while inner screws (orange) are 11mm.
    ptb - Yanıt
    I found these screws quite loose; upon reassembly, I wanted to torque them but found the case would distort towards the center, so I had to leave them fairly loose
    David A - Yanıt
    I cannot get the two outer screws out for the life of me- and afraid of stripping them. Already see I'm doing some damage. Help? What can I do?
    Olivia - Yanıt
    Are you sure you have a proper screwdriver? From my experience you really need to use the correct size and not just something that seems to fit.
    Jakub Clapa -
    Olivia, you can screw back the longer screws that go on the inside. In the photo marked with orange. Then open and close the lid of the MacBook a few times. This will fit the 4 screws more properly in the steel inner-frame and they can come a little bit loose.
    Close the lid again. Leave the inner screws untouched and begin with the outer screws (marked with red) with indeed a perfect matching screwdriver head (with a big and long grip for your hand). This worked for me perfectly without damage. Success!
    S van Dam -
    When reassembling, do not fully tighten the two 11 mm (orange) screws. When the plastic starts to flex, back it off until the strain on the plastic housing is released and leave it at that. The two 7.25 mm (red) can be snug.
    steveeb33 - Yanıt
    Same experience as David. Case warped and left screws a little loose.
    spadu79 - Yanıt
  10. Remove the two Phillips screws from the optical drive side of the computer.
    • Remove the two Phillips screws from the optical drive side of the computer.
    • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the other side of the computer.
    The screw farthest from the optical drive would not come out, all other screws came out fine with my screw driver and the screw looks ok, any tips on how to get the screw out?
    Aidan Morey - Yanıt
    With some of the screws that can happen. I had it too. This did it for the MacBook I was repairing: 1. Open the MacBook. Then press firm but gentle on the upper case with your hand or fingers while trying to loosen the screw with your screwdriver. 2. I used a different screwdriver from the same size diameter but with a much larger hand-grip. Success!
    S van Dam -
  11. There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
    • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
    • If you stand the base on end to get a better look you may displace the total of 4 grey plastic clips that hold the keyboard in place. Don't panic. They slide into slots at the top right-most edge near the CD drive.
    There will be 4 grey plastic clips just right of the DVD drive. Note their position as they will fall out in the next steps.
    tim7866 - Yanıt
    No such clips found on my early 2008 version.
    Ernie K -
    Thank you ifixit, it was huge help for me, I did it and everything just works great.....THANK YOU!
    Dako - Yanıt
    As is reported above, there a 4 friction tabs that connect to the keyboard. If they do not stay in place and stick to the keyboard, the keyboard will not go back on. Just remove them and put them in the clips, with the solid clip wall to the outside of the unit, and put the keyboard back on. Do this before reconnecting the keyboard.
    David Higgins - Yanıt
    I had no problem at all in this step, the left side was already unlocked when I open the MacBook, the right side was a little tricky but i was able to pull it out in less than a minute
    manochu - Yanıt
    The front left had an annoying little metal strip between the outside of the case and the tab. It's very easily bent, so the tab was caught on it. I spent a good deal of time trying to push and pull various things (and even just yank the @$!^ thing off), but eventually I found that if you undo the two screws you are told not to in step 7, the battery connector can be pulled up and out, leaving enough horizontal room to pull out the metal strip (with a little bit of coercion). I left it out when I put everything back together.
    James Pearson Hughes - Yanıt
    Thanks for the tip. Saved me!
    Joe -
    Because this step requires some force, make sure to double check that you got all your screws out. I finally got my gumption up to apply the necessary force required to pull up the upper case, and after 5 minutes of pulling, I look and see that the reason it wasn't coming up because I missed one screw. Ugh.
    Also, before you just shove your hands under the upper case, prying about, think twice: I cut my finger pretty bad on a sharp piece of metal.
    Thomas - Yanıt
    When reassembling, take some care to align the tabs on the right hand side next to the optical drive. Rock and slide these tabs into position. Then work from right to left, as the rest of the case is quite easy to put back together.
    Andrew Dent - Yanıt
    I took my mac apart yesterday to clean out the trackpad properly and after getting some 'help' from my grandfather (he lost 2 screws and snapped off a bit of the uppercase but i didn't have the heart to ask him to leave it alone) i tried putting the uppercase back on. it fits perfectly but the middle section closest to the screen appears slightly raised and when i go to screw in the four screws on the exterior of the laptop i can't because the hole is not at all aligned (and two of those four screws are very long). anyone know why this might be? can it be fixed/is it a common problem?
    Eliza - Yanıt
    If the upper case sticks above the optical drive, don't pull straight up, but up and to the left at the same time.
    frood - Yanıt
    Wow, pulling both up and to the left made all the difference for me, to unstick the keyboard around the optical drive.
    Neil Steiner -
    I think it is a mistake to separate the keyboard from the clips at the right side (above the optical drive) at all! Instead, after freeing the other three sides, just slide the keyboard slightly to the left, and leave the clips attached to the keyboard. For reassembly, just put the keyboard in its approximate place and slide it to the right to get those clips into position. Be sure the keyboard is really snug against the machine’s case. Then press the other three edges of the keyboard down.
    jeh -
    The plastic around the edge is very thin and cracks easily, so be gentle while using the opening tool.
    Henry S - Yanıt
    On the right side above the optical drive there are little plastic braces that latch the upper case to the main body. This is the reason why the upper case might stick here. If the above step is not working, also try to gently push the upper case sideways away from the optical drive after freeing all other sides. When reassembling make sure the braces are in their slots of the main body and not attached to the upper case. If you cannot fit the upper case evenly over the optical drive, that's probably why. In this case carefully remove them and slide them back into their slots before lowering the upper case.
    Hendryk1982 - Yanıt
    this guide was awesome. this step was easy for the broken macbook i salvaged and noticed because i got a factory replacement keyboard quite recently on my macbook in use, the 4 clips above the optical drive were TIGHT - it took quite a bit of pulling up before it came loose!
    Chinarut Ruangchotvit - Yanıt
  12. While holding up the upper case, pull up the black tab of the silver cable away from its connector. If there is no black tab, you can also use a spudger to gently pry the connector from its housing.  This connector is tall, so be sure to pry straight up. If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
    • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard (refer to second picture). They must be installed in their slots for the keyboard to snap in properly.
    • To make the reassamble process easier, it's better to pull out the clips first by pulling it straight up gently. Be careful not to put too much strength because it will break.
    When changing the topcase remember to change the sticker with the serial also! This might be important when further service or bigger repairs by apples service are needed. The serial also helps you with identifying your macbook!
    spi - Yanıt
    The entire connector broke off the logic board when I was disconnecting the keyboard just now. Be extremely careful!
    Chris - Yanıt
    I tried to remove the blacktab from the logic board, however, the black tab tore apart. The logic board is okay but the keyboard connector is torn. It has some silver wires passing through a whit plastic housing. It is the first generation of MacBook Core Duo. Do you think it can be repaired?
    Roger - Yanıt
    I could not get the keyboard off my the body... (black macbook I don't know if that makes any difference). It was stuck bottom left hand corner, so I had to bend whatever was stuck to get access to the logicboard etc... any reason why this is the case??
    Takuma - Yanıt
    not sure if this is the place to ask but my mac. doesn't start properly now it turns on and the little light on the right side turns on but keyboard leds don't and display doesn't either any ideas please?
    carlos - Yanıt
    Great repair guide! Changing the top case was pretty easy and it saved me a lot of money.
    Harry - Yanıt
    it was really easy, i had no experience whatsoever installing or unistalling mac parts (or pc either). it just took me less than 25 minutes, and i just finish and Im typing from my new upper case keyboard.
    manochu - Yanıt
    After a sucessful install of the keyboard, the select (mouse buttun equivalent) was found to not operate consistently. I called support and they are shipping a new one out to me. THIS is why I buy from ifixit - sure I can get a part for less elsewhere - but I would not get the service I get with ifixit - THANKS guys!!!
    jgreengold - Yanıt
    Note - I agree, this was VERY easy - great pictures, perfect explanations...
    jgreengold - Yanıt
    carlos kullanıcısından alıntı:
    Did you ever find an answer for this question? My computer is doing the same thing. Thanks.
    E Chambliss - Yanıt
    E Chambliss kullanıcısından alıntı:
    no i never did couldn't get help it blows to hear someone else had the same problem...im using a windows(yuk) but im getting a new mac next paycheck. if you figure it out let me know so i can fix my other one and maybe give it to my parents
    carlos - Yanıt
    Hello, I'm following this procedure because my MacBook isn't turning on due to a failure in the MagSafe DC In board, it was not charging the battery and therefore no power going in. The case was broken duirng warranty and also the MagSafe power adapter was replaced. Now it is failing again. This is an old late 2006 MacBook. Does your Mac powers on, do you hear the chime sound? or you are stuck with a hardware failure?
    Francisco - Yanıt
    Francisco kullanıcısından alıntı:
    my MacBook charges the battery and powers on i dont hear a chime and it turns on but never starts
    carlos - Yanıt
    spi kullanıcısından alıntı:
    When changing the topcase remember to change the sticker with the serial also! This might be important when further service or bigger repairs by apples service are needed. The serial also helps you with identifying your MacBook!
    How do you do it? I can't get it out
    Superb guide thank you guys
    eli - Yanıt
    This takes some nerves if there is no tab, but be confident and just prise the connector straight up.
    Andrew Dent - Yanıt
    Be very careful while you pulling the black tab! It's better to use spudger to pry the connector from it's housing while you gently pulling the black tab.
    eaksut - Yanıt
    Clips removal: its hard with finger to pull. It's better and easy off with a pry tool (I used a flat twiser) to pry from the bottom gently for each clips. It was so smooth and easy.
    Johhnie Doe - Yanıt
    After I clean everything nice… put the cable back and DO NOT TURN ON. What the !&&* happens!? Ideias my friends? :(
    Sorry my bad english!
    glecyo medeiros - Yanıt
    Getting the upper-case/keyboard off was a bit nerve-wracking. Just work away at it carefully, bit by bit.
    A small torch (flashlight for our American friends) was handy to see what was happening underneath the upper-case. Otherwise too dark.
    I used a photographic lens-cleaning blower (with the rubber squeeze bulb, just the blower, no brush) to get away the dust. Probably not as effective as canned air, but it worked well enough. I’d recommend avoiding touching anything with the tip of the blower. Keep it a few mm away.
    Les Kitchen - Yanıt
    After removing the keyboard I noticed that the side clips were not attached to the body but rather to the keyboard still. Easily removed but something to note.
    Philip Lynes - Yanıt
  13. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  14. Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    Note, if you’ve already installed an optical/SATA adapter, and you’re doing this just to replace the SATA drive, then you might be able to skip almost all of the following steps. It seems that for the sort of adapter described in this guide (with the drive secured by a plastic positioner), you should be able to leave pretty much everything in place, and swap out the SATA drive (though you might need to move the Bluetooth antenna holder out of the way).
    Unfortunately for me, mine is a different kind of adapter, with the drive secured by screws from the underside, so I still had to go through almost all the steps to get the adapter out. I can’t even remember where I got the adapter. I think it was probably from iFixit, but it might have been a different, earlier version.
    Les Kitchen - Yanıt
    Backstory is that I put an SSD in the adapter a few years back to replace a dead optical drive. And it worked with the extra drive, but it seemed to function slowly, at optical-drive rather than SSD speed. Recently, the machine stopped detecting the extra hard-drive. I don’t know why. My guess is that in an upgrade something changed in how the kernel detects devices, and it got confused by an SSD being where it expected an optical drive. (I’m running Debian GNU/Linux, it being the only way I can run up-to-date software on a machine no longer supported by Apple, and I’m a Free Software enthusiast anyway.) Your mileage may vary… Because the SATA drive wasn’t being detected, and I needed access to the data on it, I had no choice for the time being but to take out the SSD and go back to a single-drive machine. The main drive is SSD, and I’ve upgrade to the max 6GB RAM, so it’s still a pretty useful machine.
    I’m planning to put the adapter back in, just in case the void would be bad for cooling air-flow.
    Les Kitchen - Yanıt
  15. Remove the two Phillips screws from the front edge of the optical drive.
    • Remove the two Phillips screws from the front edge of the optical drive.
    • Two 3.25 mm Phillips #000, (Head: 4 mm. dia. x .3 mm thick)
    After installing the caddy successfully, I could not make the screw on the right fit in again. The distance between the hole and the caddy seemed to be too big.
    ThomasKS - Yanıt
    !! I can't remove the left screw, and ended up "screwing" it.. it's a round hole now. What should I do?
    wkurosawa - Yanıt
  16. Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
    • Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
    Pull straight up from the left
    tjkredo - Yanıt
  17. Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    • Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    The display cable was difficult to disconnect for me. I had to pull firmly and use the spudger at the same time to finally pop it off.
    supershibbydude1 - Yanıt
    I pulled firmly on the tab, while rocking back and forth slightly.
    Les Kitchen -
    Pull the connector firmly straight up.
    Eric - Yanıt
    I have found over the years that a connector puller is invaluable in these situations. I believe that I bought mine from iFixit. In steps 16 and 17 you'll have to partially de-route two cables at the base of the connectors in order to get a good grip with the connector puller.
    randy3833 - Yanıt
  18. Disconnect the (once again) newly-revealed hard drive cable.
    • Disconnect the (once again) newly-revealed hard drive cable.
    This step is not necessary
    nycstb - Yanıt
    Left Off Here
    velopro - Yanıt
    When reconnecting the Hard Drive Cable to the logic board (Step 17) I ran the HD cable on top of the microphone wire, and the other wire that runs parallel to it, when I should have run the HD cable underneath those two wires. This resulted in the hard drive not being connected on startup, and a lengthy troubleshooting session to figure this out. So save some time and install this underneath the two wires, just like you found it when taking it apart!
    mrphiliprichard - Yanıt
    I've found it very useful to take photos of wire routing on disassembly for later reference.
    randy3833 - Yanıt
  19. Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • During reassembly, be sure to route the cables beneath the tape before reattaching it.
    I was gently pulling up the tape with a spudger, but the tape snapped clean in half right at the edge of the optical drive. I'm really pretty surprised because I see no reason why it would have done that.
    Neil Steiner - Yanıt
    Leave the foil on the fan side cause you’ll be taking it off the optical drive anyway
    Luke - Yanıt
  20. Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    I had to unscrew a screw securing flat ribbons keeping cables in position between beeper and fan to reach for the dvd screw
    t0m - Yanıt
  21. Remove the 2 mm Phillips #00 screw securing the optical drive.
    • Remove the 2 mm Phillips #00 screw securing the optical drive.
    • The Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to unscrew the cable clip to free the cable enough.
    STEP 20 - IMPORTANT= This screw secures a mounting bracket on the optical drive. This bracket's eyelets are slotted. The right side of the bracket has a tab inserted in the bottom case. After removing the screw, use the spudger to slide the bracket to the left. This disengages the tab from the right side of the case, thus allowing the optical drive to be lifted out in step 23.
    xtian - Yanıt
    As an addition to xtian's note, the bracket that you need to slide right (and a spudger is very useful here) it may be because the rear right (as in the picture) of the optical drive needs to be GENTLY pushed down as the bracket end needs to slot into a hole on the right hand side of the case.
    Ernie K -
    After removing the screw gently push the metal tong (which the screw was holding) towards the fan. This will unlock the drive mount.
    Tom Roinisto - Yanıt
    Please add this notes to the actual step. I missed the comments and bent the bracket.
    huso - Yanıt
    I used a #000 Phillips.
    Eric - Yanıt
    I found it helpful to remove the screw sitting to the lower left of the speaker.
    patjmccarthy - Yanıt
    There is only one screw holding the optical drive down, the one circled in red. the one in orange is for the ground loop for the microphone and right speaker cable. Also, a spudger makes quick work of moving the cables out of the way to get to the screw for easy removal/replacement.
    Leo LeBron - Yanıt
    As I tried to refit the optical drive, the plastic mount for the brass threaded socket that receives the screw crumbled like an old tooth. Only thing for it was to ditch the plastic and superglue the brass socket into place on the case - seems to have worked. (People who design parts/fixings that involve strong materials held in place by weaker ones should be imprisoned). I also had to remove the sliding bracket on the drive and cut 2/3mm off the right hand end to get the screw hole to align with the brass socket, also seems not to have caused any harm. Never thought I would find myself lashing out with the superglue and wielding a hacksaw inside a laptop...empowered!
    muir mackean - Yanıt
  22. Lift the Bluetooth antenna board from the right side of the optical drive.
    • Lift the Bluetooth antenna board from the right side of the optical drive.
  23. Deroute the hard drive cable from along the front of the optical drive.
    • Deroute the hard drive cable from along the front of the optical drive.
  24. Lift the front edge of the optical drive and slide it up and out of the computer.
    • Lift the front edge of the optical drive and slide it up and out of the computer.
    On the the optical drive there is a sliding-bar (secured by two screws, which fixes the drive in the right edge of the Alu-frame) that has to be shifted to the left when taking the drive off. Especially, before putting the optical drive back to the computer, make sure that the the sliding bar is in its leftward position in order not to block the insertion of the drive. Then shift the bar gently to the right thereby fixing the drive's position.
    armin - Yanıt
    Thanks! Even so, I had to get the drive aligned just right, so that the sliding bar could mate with the matching slot in the case.
    Les Kitchen -
  25. Remove the following 3 screws:
    • Two 3 mm Phillips near the right speaker.
    • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
    • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
    • Santa Rosa and Penryn MacBooks do not have a c-channel. If you are disassembling either of these models, remove only the single 3 mm Phillips screw from the right speaker and skip step 26.
    If you don’t have the c-channel it seems you can skip steps 24, 25, and 26.
    mike s - Yanıt
    Santa Rosa and Penryn use a #000 phillips for the speaker screw.
    Eric - Yanıt
  26. Lift the right speaker out of its housing and set it to the side.
    • Lift the right speaker out of its housing and set it to the side.
  27. If you have a Santa Rosa/Penryn model, skip this step.
    • If you have a Santa Rosa/Penryn model, skip this step.
    • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
  28. Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
  29. Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
    • Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
    • This metal clip may not be present in all models. Be sure that the cable is free from any hold downs around this area before proceeding.
    I find it very strange that it’s omitted, but to deroute the microphone cable, you will have to unscrew the cable right next to (above) it. At least, I had to. It’s not hard, but you can’t deroute the microphone cable without derouting the other cable.
    Make sure to remember that this screw is removed when reassembling!
    FixWiki - Yanıt
  30. If you didn't remove the ground loop screw in step 20 above, remove it now.  It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
    • If you didn't remove the ground loop screw in step 20 above, remove it now. It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
    Put close attention to how the cables are laid out to get the same staking order, when reassembling I did not care about the order and as a result they were not as "Flat" as before and made the DVD drive insertion a bit more hard as it did not sit as deep as it should, so I had to re arrange the cables and once they were right the DVD drive sat perfectly. I would suggest taking a photo before re-routing them.
    Daniel - Yanıt
    For the second time that I changed an inverter I skipped to disconnect the microphone cable (steps 27 to 30) because it's really hard to wiggle the connector out of its socket and it looks very fragile.
    By doing this you can not move the display assembly far from the case BUT it's not a problem for the next steps (front bezel and clutch cover).
    I won time and did not have to replace display and microphone cables what is not easy because of the lack of place and if the SuperDrive is compressed it can block CDs.
    Not sure if that will help...
    Charlocom -
  31. Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
    • Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
    Is the silver wire really the microphone? I noticed wear right down to the wire on mine, and the macbook often has yellow/goofy looking screen, then adjusting the angle helps.
    Luke - Yanıt
    On my Penryn model, it helped to deroute the data display cable and the microphone cable from under the tabs of the subwoofer by loosening the two Phillips screws to the right of the speaker.
    randy3833 - Yanıt
  32. Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
    • Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
    The ground screw also holds down a ground loop that is part of the speaker cable. The two loops may be stuck together so you need to carefully separate them.
    kyoungdale - Yanıt
  33. Disconnect the three antenna cables from the Airport card.  There may be a square foam piece over the logic board connector. Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.)  The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
    • Disconnect the three antenna cables from the Airport card. There may be a square foam piece over the logic board connector.
    • Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.) The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
    • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there are only two antenna cables and the black inverter cable is in a different location.
    Don't pry the plastic connector from the board, but rather, the plastic connector is two pieces. Separate them.
    Joscon5 - Yanıt
    For the MacBook Core 2 Duo Santa Rosa/Penryn: the inverter cable is a bit tricky. I was fooled into thinking that there were pins which went INTO the inverter cable. Because of this, I was afraid of lifting up on the cable (off the board), but this is what you actually must do to separate them.
    For clarification, here's a pic (low-res, sorry) of the inverter cable disconnected from it's on-board plug: http://lh4.ggpht.com/_l0f6yKkaxDU/S0FOHS...
    jetrost - Yanıt
    The inverter connector comes off vertically from the motherboard.
    James - Yanıt
    Can I get a replacement connecter that the inverter cable connects to and solder it on? I broke mine taking to of how it says in the guide
    edward - Yanıt
    i also broke mine off the motherboard on accident. it appears to be a fairly clean break. is there anyone who has had luck soldering them back on?
    michael -
    Antenna connectors pull up.
    Eric - Yanıt
    About disconnecting the inverter cable. I had more luck wedging the pointed end of spludger between the PCB near the cables and the shoulder of the connector nearest the display. I then pushed the pointed end of the spludger away from the display and the connector popped up off the socket. when trying to use the spludger on the sides of the socket, i deformed the plastic edges of the socket.
    Linda Vanasupa - Yanıt
    This worked well for me too.
    Jeremiah Banks -
    Pull vertical for santa rose models as well, be delicate with this part, very tricky.
    Abraham Q - Yanıt
    The inverter cable was fine if a little fiddly, but I can't get the antenna cables back on at all - anyone got any ideas? Even with bright lights and magnifiers I can't see why they won't go back in. (And I don't know why ifixit thinks I'm called facebook -- Sam)
    facebook - Yanıt
    ... and of course as soon as I ask for help I find the answer. Don't try to push the plug vertically into the socket on the Airport board, start it at an angle with the cable running up and away from you towards the screen, then rock it back horizontal and it just clicks into place. -- Sam
    facebook -
    A method to remove the inverter cable connector that just worked great for me: I hooked a dental pick underneath the connector at the cable side (display side) and picked in right up out of the socket. I wiggled it a little first to make sure that I only had the connector hooked.
    randy3833 - Yanıt
    After destroying a similar connector on a fan replacement with a dental pick, I've decided to withdraw my recommendation to use one. Best to use the flat end of the smaller spudger and pry the connector out from under the wire (screen) side, very slowly, working from side to side.
    randy3833 - Yanıt
  34. Remove the following 2 screws from the right hinge mount: One 6 mm Phillips on the left side of the hinge mount.
    • Remove the following 2 screws from the right hinge mount:
    • One 6 mm Phillips on the left side of the hinge mount.
    • One 10 mm Phillips on the right side of the hinge mount.
    • For Santa Rosa/Penryn models, see second picture and remove:
    • One 3 mm smalller diameter Phillips on the far left.
    • One 5.2 mm larger diameter 4.2 mm head Phillips in the middle.
    • One 10 mm Phillips from the far right.
    • Lift the right hinge mount with the small plastic piece out of the computer.
    I have the regular (not Santa Rosa/Penryn) model, and instead of a 6mm Phillips screw on the left, it was a 5mm Phillips screw. It didn’t make a difference, however.
    FixWiki - Yanıt
  35. Hold the display with one hand while removing the screws from the left hinge mount.
    • Hold the display with one hand while removing the screws from the left hinge mount.
    • Remove the following 3 screws from the left hinge mount:
    • One 7.2 mm smaller diameter Phillips from the right side.
    • One 5.2 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
    • Lift the left hinge mount with plastic piece out of the computer.
    • Check that the cables on the right are not trapped under other cables.
    • Before completely disassembling, take care to see how the left hing mount fits together. When you remove the display in later steps, the hinge will pop both the left and right hinge mounts out, along with two small plastic pieces. Knowing how the mount fits together will help with reassembly.
    I tried this last night and the screen fell backward, cracking the components of the hinge. Be careful and support the screen here once you unscrew the hinges!
    TheLordSmurf - Yanıt
    What is that plastic hinge thingie called in step 34. The piece broke and I'd like to replace that.
    shawniemichael8 - Yanıt
    Can anyone else confirm what I’ve written below?…
    In my macbook, which is the regular (not Santa Rosa/Penryn) model, the longest 10mm screw is the same, but the middle screw and the right screw are both approximately 5mm. However, the middle screw is fatter/wider and the right screw is thinner.
    Also, when reassembling, make sure all three screws are easily screwed in before tightening each one. The hinge mount that you’re fastening down will wiggle a bit before being fully tightened down, possibly causing the screw holes to not line up!
    FixWiki - Yanıt
  36. Grasp the display assembly on either side, and lift it up and out of the computer.
    • Grasp the display assembly on either side, and lift it up and out of the computer.
    For those wishing to go further into the LCD, the steps are identical to the MB CD, see this repair guide for more:
    MacBook Core Duo Inverter Replacement
    MC25 - Yanıt
Sonuç
189 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
648 adet Kılavuz yazıldı
2 Yorum
As it turns out, I have a Sanata Rosa/Penryn model and I didn't even know.
Marc Carroll - Yanıt
hi
can you help me
do you know model number of lcd panel in macbook core 2 duo 1.83(MA699LL/A probably)
i want to make external display,for this i need to buy CONTROLLER BOARD
i just dont want open plastic that surround lcdpanel
thanks
Artem Nikiforov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 47
Son 30 gün: 183
Her zaman: 274,118
