Ana içeriğe geç
MacBook Core 2 Duo Memory Cover Replacement
Neye ihtiyacın var
  1. MacBook Core 2 Duo Memory Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Memory Cover Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Memory Cover Replacement, Memory Cover: adım 3, 1 resimden 1.
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. MacBook Core 2 Duo Memory Cover Replacement: adım 4, 1 resimden 1.
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
Sonuç
54 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 34,286
