Ana içeriğe geç
MacBook Core 2 Duo RAM cover replacement
Neye ihtiyacın var
    1. MacBook Core 2 Duo RAM cover replacement, RAM cover: adım 1, 1 resimden 1.
      • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
      • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
      • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
      • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core 2 Duo RAM cover replacement: adım 2, 1 resimden 1.
      • Pull the L-shaped RAM cover towards you and remove it from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these steps in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
jp en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Uhucream
827 İtibar
2 adet Kılavuz yazıldı
Ekip
Japanese Translators Japanese Translators üyesi
Community
6 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 76
Her zaman: 2,062
