Ana içeriğe geç
MacBook Core Duo Memory Cover Replacement
Neye ihtiyacın var
  1. MacBook Core Duo Memory Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    FixBot'a Sor
    Yorum Ekle
  2. MacBook Core Duo Memory Cover Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. MacBook Core Duo Memory Cover Replacement, Memory Cover: adım 3, 1 resimden 1.
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    FixBot'a Sor
    Yorum Ekle
  4. MacBook Core Duo Memory Cover Replacement: adım 4, 1 resimden 1.
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 54
Her zaman: 23,874
