Giriş
Replace a warped optical drive bezel to allow your MacBook's optical drive to accept discs again.
Neye ihtiyacın var
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
Insert the flat end of a spudger between the optical drive bezel and the plastic lower case.
Gently pry the optical drive bezel away from the adhesive securing it to the lower case enough to lift the mounting ear near the hard drive connector above the metal framework.
Lift the optical drive bezel enough to clear the metal framework and continue separating it from the lower case with your spudger.
7 farklı kişi bu kılavuzu tamamladı.
