Ana içeriğe geç
MacBook Core Duo Optical Drive Cable Replacement
Neye ihtiyacın var
    1. MacBook Core Duo Optical Drive Cable Replacement, Battery: adım 1, 1 resimden 1.
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Optical Drive Cable Replacement: adım 2, 1 resimden 1.
      • Lift the battery out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Optical Drive Cable Replacement, Memory Cover: adım 3, 1 resimden 1.
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Optical Drive Cable Replacement: adım 4, 1 resimden 1.
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Optical Drive Cable Replacement, Upper Case: adım 5, 1 resimden 1.
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Optical Drive Cable Replacement: adım 6, 1 resimden 1.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Optical Drive Cable Replacement: adım 7, 1 resimden 1.
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Core Duo Optical Drive Cable Replacement: adım 8, 1 resimden 1.
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Core Duo Optical Drive Cable Replacement: adım 9, 1 resimden 1.
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Core Duo Optical Drive Cable Replacement: adım 10, 1 resimden 1.
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Core Duo Optical Drive Cable Replacement: adım 11, 1 resimden 1.
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Core Duo Optical Drive Cable Replacement: adım 12, 1 resimden 1.
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Optical Drive Cable Replacement, Optical Drive: adım 13, 1 resimden 1.
      • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Optical Drive Cable Replacement: adım 14, 1 resimden 1.
      • Remove the two Phillips screws from the front edge of the optical drive.
      • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Core Duo Optical Drive Cable Replacement: adım 15, 1 resimden 1.
      • Disconnect the orange optical drive ribbon cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Core Duo Optical Drive Cable Replacement: adım 16, 1 resimden 1.
      • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Core Duo Optical Drive Cable Replacement: adım 17, 1 resimden 1.
      • Disconnect the (once again) newly-revealed hard drive cable.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Core Duo Optical Drive Cable Replacement: adım 18, 1 resimden 1.
      • Peel up the foil tape between the fan and the optical drive.
      • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Core Duo Optical Drive Cable Replacement: adım 19, 1 resimden 1.
      • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Core Duo Optical Drive Cable Replacement: adım 20, 1 resimden 1.
      • Remove the 2.8 mm Phillips screw securing the optical drive.
      • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
      • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
      • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
      FixBot'a Sor
      Yorum Ekle
    9. MacBook Core Duo Optical Drive Cable Replacement: adım 21, 1 resimden 1.
      • Lift the Bluetooth antenna board from the right side of the optical drive.
      FixBot'a Sor
      Yorum Ekle
      • Deroute the hard drive cable from along the front of the optical drive.
      FixBot'a Sor
      Yorum Ekle
    10. MacBook Core Duo Optical Drive Cable Replacement: adım 23, 1 resimden 1.
      • Lift the front edge of the optical drive and slide it up and out of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Core Duo Optical Drive Cable Replacement, Optical Drive Cable: adım 24, 1 resimden 1.
      • Peel up the orange tape partially covering the orange optical drive cable.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Core Duo Optical Drive Cable Replacement: adım 25, 1 resimden 1.
      • Disconnect the orange cable from the optical drive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
1Rehber Yorum
This was great to use , I was very impress with this guide to remove my optical drive.
Love it!
Stanley Reyes Jr - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 47,897
