Ana içeriğe geç
MacBook Core Duo Upper Case Clips Replacement
Neye ihtiyacın var
  1. MacBook Core Duo Upper Case Clips Replacement, Battery: adım 1, 1 resimden 1.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Upper Case Clips Replacement: adım 2, 1 resimden 1.
    • Lift the battery out of the computer.
  3. MacBook Core Duo Upper Case Clips Replacement, Memory Cover: adım 3, 1 resimden 1.
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Upper Case Clips Replacement: adım 4, 1 resimden 1.
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Upper Case Clips Replacement, Upper Case: adım 5, 1 resimden 1.
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Upper Case Clips Replacement: adım 6, 1 resimden 1.
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Upper Case Clips Replacement: adım 7, 1 resimden 1.
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Upper Case Clips Replacement: adım 8, 1 resimden 1.
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Upper Case Clips Replacement: adım 9, 1 resimden 1.
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Upper Case Clips Replacement: adım 10, 1 resimden 1.
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Upper Case Clips Replacement: adım 11, 1 resimden 1.
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Upper Case Clips Replacement: adım 12, 1 resimden 1.
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Upper Case Clips Replacement, Upper Case Clips: adım 13, 3 resimden 1. MacBook Core Duo Upper Case Clips Replacement, Upper Case Clips: adım 13, 3 resimden 2. MacBook Core Duo Upper Case Clips Replacement, Upper Case Clips: adım 13, 3 resimden 3.
    • The clips are captive to the lower case on Santa Rosa MacBooks and later and are thus not replaceable on these models.
    • The four plastic upper case clips are installed in the aluminum framework above the optical drive opening.
    • To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 43
Her zaman: 7,699
