Ana içeriğe geç
MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the pentalobe screws: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.7 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Open a gap using a suction cup: adım 2, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Open a gap using a suction cup: adım 2, 2 resimden 2.
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  3. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Separate the clips: adım 3, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Separate the clips: adım 3, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Separate the clips: adım 3, 3 resimden 3.
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  4. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 4, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 4, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 4, 3 resimden 3.
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  5. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 5, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 5, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 5, 3 resimden 3.
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  6. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 6, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 6, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 6, 3 resimden 3.
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  7. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the lower case: adım 7, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the lower case: adım 7, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the lower case: adım 7, 3 resimden 3.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  8. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Uncover the battery connector: adım 8, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Uncover the battery connector: adım 8, 2 resimden 2.
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  9. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 9, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 9, 2 resimden 2.
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  10. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 10, 2 resimden 2.
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  11. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 11, 2 resimden 2.
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 12, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 12, 2 resimden 2.
    • Fold the battery board data cable to the side and out of the way.
  13. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 13, 1 resimden 1.
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the battery: adım 14, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the hinge covers: adım 15, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the hinge covers: adım 15, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the hinge covers: adım 15, 3 resimden 3.
    • Use a T3 Torx driver to remove the four 1.9 mm screws securing the plastic covers on top of the display hinges.
    • Remove both plastic hinge covers.
  16. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the main display cable: adım 16, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the main display cable: adım 16, 2 resimden 2.
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  17. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 17, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 17, 2 resimden 2.
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  18. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 18, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 18, 2 resimden 2.
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  19. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Unscrew the antenna cable assembly: adım 19, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Unscrew the antenna cable assembly: adım 19, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Unscrew the antenna cable assembly: adım 19, 3 resimden 3.
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display board cables.
    • Use a pair of tweezers to remove the two aluminium covers.
  20. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 20, 2 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 20, 2 resimden 2.
    • Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
  21. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the antenna cables: adım 21, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the antenna cables: adım 21, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Disconnect the antenna cables: adım 21, 3 resimden 3.
    • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
    • Slide your tweezers or the pointed end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  22. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 22, 1 resimden 1.
    • Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
  23. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Pry up the antenna cable assembly: adım 23, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Pry up the antenna cable assembly: adım 23, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Pry up the antenna cable assembly: adım 23, 3 resimden 3.
    • Use an opening pick to lever out the antenna cable assembly in the areas shown.
    • Don't slide the opening pick from side to side, as there are two display cables that could be damaged in the way.
  24. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the antenna assembly: adım 24, 3 resimden 1. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the antenna assembly: adım 24, 3 resimden 2. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement, Remove the antenna assembly: adım 24, 3 resimden 3.
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
  25. MacBook Pro 13" Four Thunderbolt Ports 2020 Antenna Bar Assembly Replacement: adım 25, 1 resimden 1.
    • Remove the antenna cable assembly.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Carsten Frauenheim
113.672 İtibar
338 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.816 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 44
Son 30 gün: 206
Her zaman: 5,927
