Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Replace the I/O board, which includes the SD card slot, the HDMI port and the right USB port.
This guide requires the removal of the heat sink. Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
30 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
What do the Pins on the IO board do? the ones that can be pressed down?
