Ana içeriğe geç
MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: adım 3, 2 resimden 2.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
509.059 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.643 adet Kılavuz yazıldı
5Kılavuz Yorumları
Nice………………..!
Fred Starbuck - Yanıt
The bottom left-middle screw on my case is jammed and won’t come out—the more I try, the more I’m stripping it. Every other screw has been removed successfully, several times, with no problems. I wonder if I put in the wrong screw from somewhere else? Any ideas for removing it?
Jordan - Yanıt
do i get a laptop cover for mac book pro retina a 1502 model
naga usha - Yanıt
do i get a macbook pro retina A 1502 MODEL laptop cover (hard or soft shell)
naga usha - Yanıt
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
Jorge Ramirez-Centeno - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 48
Son 30 gün: 307
Her zaman: 54,112
