Ana içeriğe geç
MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Yanıt
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Yanıt
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Yanıt
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Yanıt
    This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
    Evan Shulman -
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
    Hi peeps,
    I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
    However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
    Any advice /close up photos is welcome here.
    dom
    colonel mustard - Yanıt
    Tip: Use post-it notes to keep track of screws
    1. Pack of post it notes
    2. Stick screws to the sticky part of the post it note
    3. Write on the post it note which step and what kind of screw it is
    ibash - Yanıt
    Hi, in order to drain the battery I am running:
    yes > /dev/null
    in 4 terminals, so the CPU maxes out at almost 99%.
    I hope this speeds up the battery draining process.
    And the backlight is at maximum brightness :-)
    You can see the cpu load in Activity Monitor.
    Its draining at 20% per 15 minutes.
    Any concerns about draining the battery in this way?
    Andre van der Ham - Yanıt
    Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
    Chat Dawgie - Yanıt
    Without rehashing what others have said, I would highly recommend reading through the steps *and* the comments for each before tackling your replacement for tips. Highlights for me were: only disconnecting what actually needed to be disconnected, rotating the spudger to release the track pad cable, a hair dryer worked perfectly fine, and the pencil outline of the battery before you remove. You got this!
    N DesRochers - Yanıt
    Installation of replacement AirPort card was easier than I had expected thanks to this guide. Thank you.
    chaslaw - Yanıt
    I use replaced SSD and it was super easy and working great. I can finally upgrade Mac OS with plenty of room to spare and no more low memory alerts. Well worth investment and didn’t have to buy new laptop
    Pete James - Yanıt
    It's interesting that this tutorial is rated Moderate even though you need to remove the battery. The battery removal tutorial which is basically the same but with fewer steps is rated Difficult.
    Marv Ruona - Yanıt
    when i pulled the screws out i arranged them in the same way they were in. the top 2 middle screws appeared to be shorter than the rest. in order to keep them in place i got a square of packing tape sticky side up, taped both sides down with 2 other pieces of tape. and then put the screws head down in the order i pulled them.
    Jason Wade - Yanıt
    Excellent instructions although checking battery and speakers aligned before fixing batteries into place is essential. MacBook good as new!
    John Foreman - Yanıt
    I find it helpful to spread a soft, slightly fuzzy cloth (like flannel) over my workspace before doing something with small parts. It keeps screws and things from rolling or bouncing away. A towel might be too plush, though, as a screw might get lost in it.
    Richard KeslerWest - Yanıt
    I cannot get the two screws (that are different than the other ones) out and now they’re stripped. Any idea what to do without using a drill?
    Honeybee94 - Yanıt
    DO NOT REMOVE SPEAKER CABLES!! The connectors are fragile. Just remove speakers and bend attached cable away from battery. Same for trackpad cable connector at front side. This cable crosses the middle of the battery. Just remove the one connector on the back side - leave front side connector attached and fold cable toward front of computer out of way of battery.
    Paul Lebow - Yanıt
  2. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Yanıt
    To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
    Peter Stoll - Yanıt
    If your old battery has swollen, the lower case may “pop” open. Don’t lose your screws!
    Maxine Loveman - Yanıt
  3. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 3, 2 resimden 2.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Yanıt
    I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
    Evan Shulman - Yanıt
    If you’re doing an iFixIt battery replacement, the replacement battery has two rubber nubs which are right where the clips are that receive these studs. Folks have been saying it’s hard to get the studs to clip back in after replacement, and I had the same issue. I trimmed the top of these rubber nubs, which are a bit bigger than those on the original battery, with some side cutters. That made the fit much better.
    Rob Gorbet - Yanıt
  4. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, Battery Connector: adım 4, 1 resimden 1.
    • If necessary, remove the plastic cover adhered to the battery contact board.
    A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
    Daniel Brehm - Yanıt
    I have done tons of these battery replacements.
    You don’t need to do anything on the list after you disconnect the battery, apart from carefully moving the speakers out of the way, and then prise up the battery modules. I just very carefully, and with little even motions, use a large slot screwdriver. Being careful to keep it flat, to not puncture the battery.
    Easy peasy. I have never had an issue after dozens of the tasks…
    davelarose - Yanıt
    Dear Sir,
    as you seem to be very much experienced with battery replacements you might perhaps give me a hint why after having removed the battery pack successfilly, the keyboard doesn't work anymore after booting the system. The Touchpad works, the keyboard backlight works but typing does not function at all.
    I only disconnected the battery connector and touched nothing else. I am quite desperate …
    Gerd Uyan -
    I agree with Dave la Rose, provided you use heat rather than solvent to remove the old battery (or possibly floss, haven’t done that). Please see my comment further down this thread on how to use an iOpener for correctly heating the glue joint
    I. Margaronis - Yanıt
    After removing battery contact board plastic. My screwdriver accidentally fell and touched the battery board. And it short circuited. Now my battery doesn't charge. My laptop doesn't work without charger now. shuts after a few minutes of use. Can i fix it without sending it for repairs?
    Phillip Ngwenya - Yanıt
    Is replacing the battery necessary?
    Ralph Louis - Yanıt
    How do we know if it's necessary to replace the plastic cover adhered to the battery contact board?
    What are the factors that would require that?
    Lux - Yanıt
  5. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 5, 2 resimden 2.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Yanıt
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Yanıt
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Yanıt
    Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
    Jaden Salama - Yanıt
    The connector is no more than 1mm thick… the socket is 3-to-4mm deep so make sure you’re trying to remove the connector itself, and not pulling at the socket.
    Richie Egg - Yanıt
    Thank you Richie I was trying to lift the socket.
    be careful the little square block is actually made of 2 parts and you only have to lift the upper part as Richie said
    ilyes - Yanıt
    You can do it from the side like the picture, but i would recommend twisting almost like a screw driver once you have leverage under the overhanging part of the left side like in the picture. Twist the tool so that it starts to put pressure on the top, until you’ll hear it click out. You can be somewhat forceful but it shouldn’t require a lot of strength. Guiding the tool with one hand and twisting with the other is a good way to attempt this.
    Colin Nowers - Yanıt
    After I put the battery back I found out at this step that the new battery connector was off by 2 mm (because I installed my battery slightly off). Since the connector is rigid, I removed it’s plastic cover (just like we all did in Step 4) to free the cable, which allowed me to bent it enough to properly plug the connector.
    Marc - Yanıt
    Simple question: why we need to do this, I mean, disconnect battery from main board?
    Bin Zhu - Yanıt
    Well, I’m reading this step in the battery replacement repair guide, so it’s pretty critical to disconnect the battery from the main board. I’m guessing these steps are reused in other guides where disconnecting the battery might not be such an obvious need.
    surf -
    Also wondering the same. I came here from a link to replace the fan. Is it necessary to disconnect the battery inorder to replace the fan?
    Chris Andrews -
    The connector wires from the battery to the connector are long
    You'll have to bend them downward and into the small cove that exists so the connector can fit in place.
    So use the a plastic card or flat end of the spudger to bend them downward and folded a bit back so the connector will fit in place.
    Use your old battery as a guide for how they should be bent.
    RON BUENO - Yanıt
    Hi All ,
    I followed the instructions step by step and changed the board successfully and reconnected everything back. When I powered it back on I can see it is charging again however it just displays a black screen and no display. Keyboard light comes on as well and the apple logo light on the back lid also turns on. Not sure what is wrong ? It has been charging for more than 15 minutes and still no joy. Anyone able to help solve or identify the issue .
    Thanks
    Kaleem - Yanıt
    The connector cover is slightly wider and longer than the socket (<1mm) so there is a small "lip" around the top that can be used to lift it.
    If your are not familiar with those repairs, and as with most of those connections, I recommend to take the time to observe your computer and the pictures from the tutorial, reading instructions and comments before starting each step. This battery connector needs both a bit of force and of precision. For a battery repair the connection of the new battery is a bit more tricky, you need to have your battery in the right position and to force it a bit the connector
    David Obis - Yanıt
  6. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 6, 1 resimden 1.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Yanıt
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Yanıt
    @sebasgaes, shoot, I'm only part way through the process, but I skipped this step thinking it wasn't necessary. I'm only through step 12 right now, but is there a fix if my machine doesn't recognize the wifi hardware after I've put it all back together? I don't see reference to the "I/O board cable" anywhere else in the instructions, so I'm confused about your mention of that...
    jiclark - Yanıt
    UPDATE: I completed the job, rebooted, and all is well, wifi and all. Thanks anyway; gotta love iFixIt!!
    jiclark -
  7. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 3.
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
    I managed to just move the cable without having to disconnect whilst replacing my MagSafe connector
    lewismacqueen - Yanıt
    Pull straight OUT not up.
    Mmm ttt - Yanıt
  8. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 8, 2 resimden 2.
    • Pull the DC-In board connector straight out of its socket on the logic board.
    das Kabel ist oberhalbt ab Weg zur Ladeeinheit angeklebt. Vorsichtig lösen hilft ;)
    connector is glued to a silver covering on the way to the charchingunit.
    doaskwhy - Yanıt
    I had this problem too - fortunately I had the iOpener handy - heated that up in the microwave and applied it to the area where the cable is glued and the adhesive loosened!
    Sanjay Aiyagari - Yanıt
    The cable is glued down but in my case it was easy to gently pry off with a knife blade.
    sqeeezy - Yanıt
  9. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 9, 1 resimden 1.
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
  10. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 10, 3 resimden 1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 10, 3 resimden 2. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: adım 10, 3 resimden 3.
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
    Before tightening the screws on the DC board, it helps to push it slightly outwards so that it seats against the case.
    Russell Hodin - Yanıt
    I just finished this install. It took me three hours to think about it and 20 min to do it. Fixed my problem right away. I am thrilled. Thank you SO much.
    samgo777 - Yanıt
    Thank you for the awesome step by step guide… the actual job took about 5 min… but while at it, cleaned the fan… you guys are the best.
    Calcasmy - Yanıt
    Step 9: My board held in place by 6-point screws. 5-point driver would not loosen.
    Overall - easy job, good instructions.
    pkeller - Yanıt
    Hi there! That’s a Torx screw (six points) not a pentalobe (5-points), as noted in the instructions it’s a size T5 Torx =) Great job on your repair!
    Sam Goldheart -
    Hey, I’m seeing no green light when I use my charger or any charger, is this maybe the culprit? Or the battery? Any advice would be awesome!
    Billy May - Yanıt
    it would be the charging port. i had to wiggle mine just to get it to charge.
    Gabriel Zepeda -
    After replacement still no green light on the charger (also when the battery is unplugged)…any advice pls?
    Michal Perner - Yanıt
    I have followed the as described (very clear, thank you!) but there is unfortunately still no green light on the charger, any advice what I could check?
    Paula Larsson - Yanıt
    Early 2015 Macbook pro. Had the same problem with no green light until I flicked the plug up and done a couple of times without breaking the magnetic adhesive field, in other words did not break the magnetic connection between the plug and the port. Doing this 2 or three time seemed to excite/entice/inspire the green light and the charge system to engage. Not sure whether there is a a physical issue with the port or an electronic issue with the charge circuit that would require a more sudden jolt from the initiation of the charger given the slight distance from the connector. Similar to the amperage increase of of the distance of spark plug wire to a spark plug but...it has worked for this application. I also change out the battery as it was in an expanded condition. The same problem with the charge initiation existed prior to the battery change and doesn't seem to have modified its behavior any since the battery swap. Also, green light in the past would be yellow, and charge, when green wouldn't?
    Henry - Yanıt
    Sweet thanks! Used a MagSafe 1 charger in my a1502 MacBook Pro (MagSafe 2) I had to grind a bit the aluminum of the MagSafe 1 plug so that it fit, was charging fine but next morning it wasn’t charging with any of the chargers so this was the fix, easy 5 min job.
    As I researched in YouTube MagSafe 1 can kill this piece so it looks like I’m stupid ✌🏼
    Thanks again 🙏🏼
    Charlie garcia - Yanıt
    Thanks!!! First class instructions on MagSafe DC-In Board Replacement. Apple were not able to repair my computer as it is no longer supported and they no longer had the necessary part available. I sourced the necessary part and with the help of these instructions now have a working laptop again.
    Klaus - Yanıt
Sonuç
42 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
502.810 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
5 Yorum
Since a few days the area around the MagSafe-DC is getting quite hot, regardless of wether the Mac is running or idle. Does this have anything to do with the MagSafe-DC? Any recommendations?
Nils Fenske - Yanıt
Hi Folks,
Just went through these very clear steps on replacing the DC-in board after the pins on my old one were burned.
First off, success…ish with the replacement and the mac is back to charging again in high spirits. However, I am now notified of a “service battery" beneath the charge drop down menu. In checking the system information, the battery is at a cycle count of 824.
I am not quite sure what to do at this point and appreciate any tips.
Best,
random guy on the internet
Joseph Van Linn - Yanıt
Replace the battery.
maccentric -
Hi there !
My mac won't charge the freshly replaced new battery... event tho it's running fine and recognized by the system...
I've been Changing the battery / Reseting SMC & NVRAM / Clean install on Monterey...
It still tells me :
Power source : power adapter
Battery is not charging
Do you think replacing the DC-in board would help ?
Thanks for your advices !
pulla - Yanıt
I’ve replaced my charging cables and battery. Will be replacing the charging port but if it still doesn’t charge … what might be the problem?
vp3130 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 55
Son 30 gün: 263
Her zaman: 28,742
