Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Prereq only.
  1. Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  4. Move the antenna cables aside, clear of the AirPort board. Move the antenna cables aside, clear of the AirPort board.
    • Move the antenna cables aside, clear of the AirPort board.
  5. Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board. Gently pry the AirPort board upwards, but do not remove it.
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  6. Pull the AirPort board straight out of its socket on the I/O board. Pull the AirPort board straight out of its socket on the I/O board.
    • Pull the AirPort board straight out of its socket on the I/O board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 57
