Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement, Battery Connector: adım 1, 1 resimden 1.
    • Remove the plastic cover adhered to the battery contact board.
  2. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 2, 1 resimden 1.
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  3. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 3, 2 resimden 2.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  4. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 4, 1 resimden 1.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  5. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: adım 5, 2 resimden 2.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 251
