Giriş
Have your MacBook Pro feet seen better days? Use this guide to give your Late 2012 MacBook Pro Retina a fresh set of feet.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$16.96
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
6 farklı kişi bu kılavuzu tamamladı.
