Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
Use the tip of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer.
Gently push the edges of the display data cable connector away from its socket on the logic board.
Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Carefully pull the left fan ribbon cable out of its socket.
Move the left fan ribbon cable aside to reveal a hidden screw securing the logic board assembly to the upper case.
Remove the following screws securing the logic board to the upper case:
Eight 3.3 mm T5 Torx screws
One Phillips #00 screw
Two 3.1 mm T5 Torx screws
Remove two more screws, from the MagSafe DC-In board in the upper right corner (second image).
Two 3.4 mm T5 Torx screws
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal.
Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
