Giriş
Use this guide to replace the right speaker.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
Move the SSD cable connector out of the way.
14 farklı kişi bu kılavuzu tamamladı.
4 Comments
Thanks for the steps, it worked. But now I am getting Wi-Fi- No hardware installed and Bluetooth Not available error
it worked but the cam is not working now :(
I was able to fix the right speaker using the solvent used to remove the battery provided by iFixit.
What do you mean you fixed the speaker? I have my speakers producing distorted sound on my macbook pro late 2012. Did you mean you fixed the sound problem? Please advice.
azn -
