Ana içeriğe geç
MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: adım 1, 2 resimden 1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: adım 1, 2 resimden 2.
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
  2. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 2, 3 resimden 1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 2, 3 resimden 2. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 2, 3 resimden 3.
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  3. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the SSD assembly from the upper case.
  4. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
  5. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 5, 2 resimden 2.
    • Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
    • Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
    • Only lift the SSD up far enough to grab the sides of it with your fingers. Lifting it any more may damage the card or socket.
  6. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 6, 2 resimden 1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: adım 6, 2 resimden 2.
    • Carefully pull the SSD straight out of its socket on the SSD tray.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 165
