Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Prereq for removing the upper case and battery.
  1. Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  2. Remove the SSD assembly from the upper case.
    • Remove the SSD assembly from the upper case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 546
