Ana içeriğe geç
Giriş
Use this guide to replace the upper case. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
    Toby Thurston - Yanıt
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. The lower case is connected to the upper case at the center, with two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. Remove the plastic cover adhered to the battery contact board.
    • Remove the plastic cover adhered to the battery contact board.
    This plastic cover wasn’t included with the new battery so I placed the original one back in. Was it supposed to go back in? This detail wasn’t clear since the original cover didn’t fit exactly over the newer battery connector. Plus any stickiness of adhesive that may have been there was gone.
    arnolfo santoro - Yanıt
    Hi, any issues with you computer after a year? I didn’t put mine back in either…
    Kevin Burlinson -
  4. Remove the following screws securing the battery connector board to the logic board:
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    Top screw in this image was not a T6. I found that a T5 bit fit this one.
    Alex Grayson - Yanıt
    I can not put back top screw holding the plastic part. Help please
    Tatiana Garcia - Yanıt
  5. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    Is adhered to screw beneath, so lift firmly and slowly.
    Andrew - Yanıt
  6. Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    I lost this screw! How important is it? Will it be okay with just the 3 previously removed screws?
    Gerardo Jimenez - Yanıt
  7. Carefully lift the battery connector board up off the logic board. It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  8. Grasp the Interposer with tweezers. An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    WHy to remove battery contact board? Replace can happen without it also, right.
    Behram Beldagli - Yanıt
    You don’t want to work on a live system as you could damage parts
    Dan -
    How can I remove interposer I m not able to remove it
    Raunak - Yanıt
    you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
    duncan rmi -
    What happens if the Battery Contact Board fails?
    racoon2956 - Yanıt
    Be extra careful when tightening down on the interposer. When I powered on upon completion, the battery was not connected. When I opened it back up, I saw that one of the little metal nubs holding the interposer in place had snapped off (the one on the side, not the corner). I was able to carefully tighten the wide head screw back in, watching the alignment, and the battery was successfully recognized. Hopefully the connection holds up.
    Doug Krieger - Yanıt
  9. Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board. When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    I keep my fingernails fairly long, very handy for many computer repair jobs. This gives me 10 spudgers over which I have very fine muscular control. It is far easier to pop some of these tiny delicate MacBook parts loose with my nails.
    Ben Myers - Yanıt
  10. Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector. Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    This step is NOT really necessary. The trackpad can be removed with this cable still in place.
    Robert - Yanıt
  11. Lift and remove the I/O board data cable from the MacBook Pro.
    • Lift and remove the I/O board data cable from the MacBook Pro.
  12. Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board. Move the SSD cable connector out of the way. Move the SSD cable connector out of the way.
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
    Because it is attached to the battery with a tiny bit of tape near where the spudger is in the picture, this cable should probably be loosened. But it is NOT necessary to remove the speaker entirely.
    Robert - Yanıt
  13. Wedge the flat end of a spudger beneath the right speaker cable connector. Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Wedge the flat end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
    When reassembling be careful that the right speaker wire is flush against the battery. At first, it was slightly touching the airport/bluetooth board causing wifi and bluetooth to not work after restarting.
    Stu - Yanıt
    NOT truly necessary to remove either speaker.
    Robert - Yanıt
    Looks like the pointy end of the spudger tool is used in the picture. That's what I used.
    bill wiley - Yanıt
  14. Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case: Two black 6.8 mm screws
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • Two black 6.8 mm screws
    • One silver 6.3 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
    There are two 6.8mm screws, both fit to the side of the Macbook.
    Bhoom Suktitipat - Yanıt
    Confirming, 2x T5 6.8mm, one with metal sponge stuff on top. And one T5 6.3mm on the bottom right.
    Joris Sewandono - Yanıt
  15. Lift and remove the right speaker out of the upper case. If necessary, de-route the right speaker cable from its channel in the upper case.
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
    NOT necessary to remove this speaker.
    Robert - Yanıt
    Yes it is…the speakers cover up the three screws on each side that hold in the battery.
    Redwolf - Yanıt
  16. Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board. Gently bend the headphone jack cable to 90° up from the logic board. Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  17. Wedge the tip of a spudger beneath the left speaker cable connector. Gently pry the left speaker cable connector  up off from its socket on the logic board.
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
  18. Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    The 6.3mm screw appears to be on the lower central part of the Macbook that I'm working on.
    Be very careful on this step. If you aren’t you can snap the plastic on the corners where the screws go in. Remember to go slowly when spinning the screws back in, it doesn’t take gorilla torque to tighten them, just take it easy!
    Stacey Deel - Yanıt
  19. Lift and remove the left speaker out of the upper case. Lift and remove the left speaker out of the upper case.
    • Lift and remove the left speaker out of the upper case.
  20. Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  21. Remove the SSD assembly from the upper case.
    • Remove the SSD assembly from the upper case.
  22. Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total). Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
  23. The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    Steps 24-34 are UNNECESSARY for this repair! Removing the adhesive portion of the battery is not required to remove the trackpad. Just lift up the top part of the battery that is screwed in and unplug the trackpad cable.
    bizwfshane - Yanıt
  24. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  25. Now that your MacBook Pro is fully prepped, it's time to prep yourself. iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  26. Pull off the black rubber stopper from your bottle of adhesive remover. Twist to loosen or remove the bottle cap before you cut the applicator tip. This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  27. Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    Can I do this without adhesive remover and just rip off the cells?
    Benoît Mussche - Yanıt
  28. Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell. Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive. Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
    This is the most difficult step. The tip of my spudger got bended and the aluminum case damaged it.
    Ahmed Almulhim - Yanıt
    I also broke a spudger trying to do this. Eventually I figured out it is easier to go in diagonally from the corner, just to one side of the screw hole, and lever until you hear the adhesive pad tear and give way.
    Matt Sephton - Yanıt
    we use a hair dryer and gently blow hot air in between the battery for a good minute before trying to lift it with a spunger. It worked wonderfully! When lifting, just give it constant force upward and you'll hear the battery slowly breaking away from the macbook, and we don't even see glue residues on our macbook at all. Just be patient. :)
    Allen Lin - Yanıt
    Just a note to say that the above comments were written before the liquid adhesive remover was added to the guide—you should definitely NOT be breaking any spudgers using the current procedure, which requires very little force. I recommend using plastic cards rather than spudgers—it's pretty easy to slide them under each battery cell and separate the adhesive once the solvent has done its work.
    Jeff Suovanen - Yanıt
    This is much easier to do using a plastic card. Just slide the card under the side of the battery and rock it back and forth. The battery will separate pretty quickly with minimal residue.
    lukecparr -
    by a plastic card, do you mean a credit card type thing? thanks in advance.
    Jennifer McPherson - Yanıt
    Exactly—one of these or an old credit card should work fine.
    Jeff Suovanen -
    I second this, I also used an old credit card and it totally worked! I did not use any heat or liquid
    yas.siqueira - Yanıt
  29. Insert the spudger along the left-hand side of the leftmost battery cell. Run the spudger up along the left side of the leftmost battery cell. Slightly pry the leftmost battery cell to release it from the adhesive.
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
  30. Repeat the above steps to separate the adjacent battery cell from its adhesive: Apply a few drops of liquid adhesive remover under the battery cell. Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a few drops of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
    I used a flat metal spudger coated with some acetone to slide under the batteries and loosen the adhesive. My plastic spudger broke early on. Finally, I used a plain old large flat-head screwdriver to pry the battery cells loose.
    Ben Myers - Yanıt
  31. Insert the flat end of a spudger underneath the larger leftmost battery cell. Carefully wedge the spudger inwards, being careful to not damage the battery cells. Pry the larger leftmost battery cell up off the upper case.
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
  32. Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case. Leave the battery cells resting on top of the upper case as shown in the third picture. Leave the battery cells resting on top of the upper case as shown in the third picture.
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
  33. Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro. Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell. Be careful not to puncture or otherwise damage the battery cells.
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
    Puncturing the battery’s protective covering can lead to release of caustic fumes or fire.
    Chris Leeds - Yanıt
  34. Lift the battery as a whole up out of the upper case, and remove the battery. Before installing a new battery, remove all the old adhesive from the MacBook Pro's case. With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
    During battery replacement take care to position the two left and right battery packs inwards and upwards towards the macbook center such, that there is sufficient space for reinstallation of the two speakers!
    Fred Ziegler - Yanıt
    If you're replacing the top case that includes a new battery, can't you skip removal of the battery?
    jaredcastello - Yanıt
    Yes!! If uppercase Assembly(Includes Trackpad, keyboard, Palmrest & BATTERY) is being replaced, there is no need to remove battery from old uppercase assembly.
    lamajr -
    Wie setze ich die Zyklen wieder auf 0 wenn ich einen neuen Akku verbaut habe?
    Albert Zweistein - Yanıt
    @Albert: you don’t need to reset the cycles as it is done automatically.
    John Wayne - Yanıt
    When you are at this step and before you put the new battery in, take the time to clean your computer really well. You will be surprised how much dust/dirt and even pet hairs have gotten into your computer. After I removed the battery, I use a little more of the acetone to clean the bays up and after it dried, I used a tiny bit of Isopropyl Alcohol to make sure there was a good clean area for the new bonding. Make sure you clean the fans. Don’t use a toothbrush or anything like that. If your have a Lowes or Home Depot, you can buy a shop vac attachment kit for about $20, it’s well worth it. Don’t use that air in a can crap, it will put moisture on circuits. Take your time, it’s not a hard task to do everything, just use a little patience.
    Stacey Deel - Yanıt
    thanks to everyone for the helpful comments along with this really good tick list of things to do. The main thing I have learned is, I don’t have the patience to do this so I am taking my macbook pro (early 2013) 90 odd miles to my nearest Apple store with a Genuis bar. They can sort it for me. They might charge a lot to do it, but at least it will be them risking messing the process up not me! Thanks again.
    Really well done on this. I followed it to a T. Perfect. Thank you for all your work on this.
    Stephen Johnson - Yanıt
    Excellently communicated.
    Andrew Goldberg - Yanıt
    I wouldn’t have thought to drain my old battery! (Which means I cannot begin my ‘new battery install’ until later today.
    Hi all,
    After installing the new batteries, my mac is not powering up… Do i need to charge the battery first and then check again? Have anyone faced similar issue before?
    My 1st battery from ifixit came out to be defective and it caused fire at the centre of the long battery. I have got a replacement for the defective piece which i have installed now. However, now i am worried that connecting to power could lead to any potential fire / harm to my mac???
    Already i have spent lot of time in this and it would be very upsetting if this battery spoils my mac!!!
    Any suggestion people???? thanks in advance!
    BR,
    Vijay
    Vijayaprasath Rajendran - Yanıt
    Hi Vijay!
    Uh-oh, we’re sorry to hear about the battery trouble!
    Our batteries come with a 1-year warranty, so this would definitely be something we can assist with. Please feel welcome to reach out via help.ifixit.com and provide our Support team with your order number so that they can look into these battery troubles with you.
    Thanks!
    Kadan Sharpe -
    My Macbook Pro late 2012 battery is swollen. All 6 cells are. I noticed it when I replaced the cooler paste using your excellent guide.
    This Macbook has become a desktop Mac, I don’t carry it around much anymore. Can I just remove the old battery, dispose of it in appropriate channel and use my Macbook Pro without battery always on power cable? This will also increase ventilation. Or will the Macbook Pro refuse to start up in the absence of the battery? I remember this worked on the white Macbook back in the days.
    Hi All,
    Just replaced battery, and am typing this on the live MacBook. The unit fired up as soon as I plugged in the power adapter. Nice. The battery percentage indicator said the battery had approximately 85% power charge. Is this normal? If not, what steps should I take to ensure that this battery is properly calibrated?
    Cheers,
    James
    James Pineda - Yanıt
  35. Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board. It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    • Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  36. Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board. It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
  37. Move the iSight camera cable aside. Move the iSight camera cable aside.
    • Move the iSight camera cable aside.
  38. Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board. Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
    • Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
    • Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
  39. Use the tip of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
  40. Use the tip of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
    • Use the tip of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
  41. Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
  42. Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer. Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer.
    • Use the tip of a spudger to rotate the pull tab secured to the display data cable lock toward the DC-In side of the computer.
  43. Gently push the edges of the display data cable connector away from its socket on the logic board. It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket. Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
    • Gently push the edges of the display data cable connector away from its socket on the logic board.
    • It is recommended "walk" the connector out of its socket. Simply push the top and bottom corners of the connector and carefully "walk it out" of its socket.
    • Pull, but do not remove, the display data cable connector out of its socket and carefully move it out of the way.
  44. Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Carefully pull the left fan ribbon cable out of its socket.
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Carefully pull the left fan ribbon cable out of its socket.
  45. Move the left fan ribbon cable aside to reveal a hidden screw securing the logic board assembly to the upper case.
    • Move the left fan ribbon cable aside to reveal a hidden screw securing the logic board assembly to the upper case.
  46. Remove the following screws securing the logic board to the upper case: Eight 3.3 mm T5 Torx screws
    • Remove the following screws securing the logic board to the upper case:
    • Eight 3.3 mm T5 Torx screws
    • One Phillips #00 screw
    • Two 3.1 mm T5 Torx screws
    • Remove two more screws, from the MagSafe DC-In board in the upper right corner (second image).
    • Two 3.4 mm T5 Torx screws
  47. Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal. Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
    • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal.
    • Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
  48. Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  49. Remove the following two screws securing the I/O board to the upper case:
    • Remove the following two screws securing the I/O board to the upper case:
    • One 3.53 mm T5 Torx screw
    • One 4.89 mm T8 Torx standoff screw
  50. Carefully pull and remove the I/O board away from its recess in the upper case. Carefully pull and remove the I/O board away from its recess in the upper case.
    • Carefully pull and remove the I/O board away from its recess in the upper case.
  51. Remove the two 3.4 mm T5 Torx screws securing the headphone jack to the upper case.
    • Remove the two 3.4 mm T5 Torx screws securing the headphone jack to the upper case.
  52. Lift and remove the headphone jack out of the upper case. Lift and remove the headphone jack out of the upper case.
    • Lift and remove the headphone jack out of the upper case.
  53. Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges. Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
    • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
  54. Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case. Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
    • Remove the 3.2 mm T5 Torx screws (one on each side) securing the aluminum hinge brackets to the upper case.
  55. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
  56. Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case. Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
  57. Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown. While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  58. Grip both halves of the device, one in each hand. Gently push forward on the bottom half of the device to detach it from the display assembly. Carefully set each component aside, making sure to set down the lower half keyboard-side down.
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
  59. Remove the following screws securing the trackpad to the upper case:
    • Remove the following screws securing the trackpad to the upper case:
    • Four 1.4 mm Phillips #000 screws
  60. Wedge the spudger between the trackpad ribbon cable and the upper case. Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
    • Wedge the spudger between the trackpad ribbon cable and the upper case.
    • Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
  61. Insert the tip of a spudger in between the trackpad ribbon cable and the upper case. Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
    • Insert the tip of a spudger in between the trackpad ribbon cable and the upper case.
    • Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
  62. Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case. Remove the trackpad from the upper case.
    • Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case.
    • Remove the trackpad from the upper case.
  63. For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
    • For this step, it is recommended to use a heat gun or hair dryer to soften the adhesive securing the microphone assembly to the upper case. You may be able to remove it without doing so, but will risk damaging the microphone cable.
    • With the heat gun set to low, heat the microphone assembly to loosen the adhesive attaching it to the upper case.
    • Be very careful not to overheat the microphones or upper case. Keep in mind that the plastic keyboard is on the other side—too much heat in a single place can melt keys.
  64. Use the tip of a spudger to remove the piece of tape covering one of two microphones. Grasp the piece of tape with a pair of tweezers and remove it. Grasp the piece of tape with a pair of tweezers and remove it.
    • Use the tip of a spudger to remove the piece of tape covering one of two microphones.
    • Grasp the piece of tape with a pair of tweezers and remove it.
  65. Repeat the same procedure as the previous step to remove the tape covering the second microphone. Repeat the same procedure as the previous step to remove the tape covering the second microphone. Repeat the same procedure as the previous step to remove the tape covering the second microphone.
    • Repeat the same procedure as the previous step to remove the tape covering the second microphone.
  66. Wedge the tip of a spudger underneath the microphone assembly cable. Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case. Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
    • Wedge the tip of a spudger underneath the microphone assembly cable.
    • Run the spudger up along the bottom of the microphone assembly cable to separate it from the upper case.
  67. Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive. At this point the second microphone should be completely detached from the upper case.
    • Gently wedge the tip of a spudger underneath the second microphone and push inwards to loosen the adhesive.
    • At this point the second microphone should be completely detached from the upper case.
  68. Carefully pry the first microphone up off the upper case. Carefully pry the first microphone up off the upper case.
    • Carefully pry the first microphone up off the upper case.
  69. Lift and remove the microphone assembly out of the upper case.
    • Lift and remove the microphone assembly out of the upper case.
  70. Upper case remains.
    • Upper case remains.
    Hey guys
    Can i just replace the keyboard in this type of mac? I've ordered one online as the P key has died.
    I can't find just a keyboard replacement guide but hope I can just replace that cheaper component...
    Cheers
    B
    Bill Wood - Yanıt
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Wow, it worked! I am computer literate but have not taken my computer apart in years. Your photos and attention to detail were much appreciated. Any woman can and should attempt to do this herself. Thanks so much for the great tutorial!
Tricia
Patricia - Yanıt
lamajr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 34
Son 30 Gün: 128
Her zaman: 15,047
