Ana içeriğe geç
Giriş
Use this guide to replace the Retina display, display glass, and iSight camera assembly.
    • Two 2.3 mm Pentalobe screws
    • Eight 3.0 mm Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Yanıt
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
    Alex Birkett - Yanıt
    Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
    addvariety -
    the macbook in the picture is 2012. does it has the same structure as 2013?
    Edison - Yanıt
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Yanıt
    is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
    monsieurescargot - Yanıt
    Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
    Antoine Thornton - Yanıt
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Yanıt
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Yanıt
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Yanıt
  2. The lower case is connected to the upper case with two plastic clips near its center. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    There are two screws that are shorter-they go to the back near the vent.
    wrbandllm - Yanıt
    This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
    addvariety - Yanıt
    What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
    Tommy Huang - Yanıt
    When I got the back off, I found this piece loose, any idea what it is? about 9mm long frosted plastic
    https://imgur.com/a/tYaxGdG
    Fred Anderson - Yanıt
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Yanıt
  3. If necessary, remove the plastic cover adhered to the battery contact board.
    • If necessary, remove the plastic cover adhered to the battery contact board.
    Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
    jodieabc - Yanıt
    There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
    Jaime Leonard - Yanıt
  4. Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board. Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Yanıt
    I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
    salvatorebarbera -
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    Hi,have you find the solution for your battery? I also have same problem, run with plugs but it battery not supporting… as soon the plug of it goes off
    Jewel Rahman -
    Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
    Steve - Yanıt
    Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
    Vadim Gribanov -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Yanıt
    Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
    Caleb Steinborn -
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
    Parth Gudhka - Yanıt
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Yanıt
  5. Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Yanıt
    Not sure I understand: did leaving the battery plugged in permanently broke the I/O board (or anything else)?
    Adrien Izzet -
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Yanıt
    That’s a great idea!
    David Lilliebridge - Yanıt
    I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
    dbrick - Yanıt
  6. Carefully remove the rubber fan bumper from the edge of the heat sink. The fan bumper wraps around the heat sink and fits into the fan duct slots. During reassembly, be sure to fit the tabs into the notches in the fan duct. The fan bumper wraps around the heat sink and fits into the fan duct slots. During reassembly, be sure to fit the tabs into the notches in the fan duct.
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into the fan duct slots. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  7. Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
    • Insert the tip of a spudger under each of the antenna cables near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
    I struggled with reconnecting these, and in the process accidentally ripped the connector away from the wire. Is there anything I can do to reattached it?
    Vanessa schroll - Yanıt
    This is most difficult and time consuming portion of this entire procedure. Make sure to lift the connectors straight up - not to damage them. The reconnection of the contacts may take several tries. USE CARE AND BE PATIENT! You will eventually get them to connect.
    Darius - Yanıt
    does anyone have advice on what is the best tool to use for reconnecting? this is definitely the hardest step to reassembly
    M N - Yanıt
    When reassembling, I used tweezers to line them up and the spudger to push them down.
    Joshua Johnson - Yanıt
    thank you Joshua, this helped me get them. they do take a bit of patience but it’s worth taking your time.
    Kevin Lynch -
    everything else was easy... I still haven't managed to figure this step out... good luck in your repair
    M N - Yanıt
    I got it! line the wire up; push the top part of the metal and give it firm pressure; they should snap in and connect
    M N - Yanıt
    You'll get 'em in. Work gently. Make sure they're exactly over top the bottom pins. Press down with a flat smudger. It took me a lot of gentle work to get them in.
    Kent - Yanıt
    I saw the sleeves on these.. and when looking at the replacement display saw they matched exactly and took the chance it was intentional. The only thing that got me.. was the bottom panel screws.. didn't know there were 3 types.. (should have known though, I mean right?! LOL Apple (rolls eyes) They could do like Samsung and use one screw for everything.. but oh no.. there is some OCD engineer that just likes SCREWING with people!
    Tim - Yanıt
    Pro Tip: When reassembling, do not screw on the metal tab attached to these connectors (part of step 15) until after you have all 3 connected. This gives you uninhibited range of motion for the 3 wires. Go slow as other commenters have said. Start with the shortest wire first. Once all 3 are connected, screw on the metal tab with those 2 screws. Finally double check that all 3 are still connected.
    D B - Yanıt
  8. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    First, lift the flat cable just off the board as it is normally “stuck” to the board. This will help the connector to release from the socket.
    John Lopinto - Yanıt
  9. Peel the iSight camera cable up off the fan housing. Peel the iSight camera cable up off the fan housing.
    • Peel the iSight camera cable up off the fan housing.
  10. Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board. During reinstallation, be sure to fully reseat the display connector tab. During reinstallation, be sure to fully reseat the display connector tab.
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • During reinstallation, be sure to fully reseat the display connector tab.
    This is pulled straight out to the side of the Macbook, not up.
    nmackaron - Yanıt
    Thanks for adding this comment !
    jrbhome - Yanıt
    Please use a nylon black stick to lift the lock bar up and push the connection apart reason being is the lock bar should not be pulled on and by pulling on it like shown may cause damage to the MLB/DISPLAY connection and then you’re into not just a display repair but a MLB on top of it!!!
    Dutchie - Yanıt
    hello, im trying to do this because im experiencing a blackscreen problem. Id like to do this but my macbook looks so different than this one. Could anyone help me?
    Karla Díaz - Yanıt
    If it doesn’t look like this, you’re looking at the wrong guide.
    maccentric -
  11. Remove the rubber hinge covers from the right and left display hinges. Remove the rubber hinge covers from the right and left display hinges. Remove the rubber hinge covers from the right and left display hinges.
    • Remove the rubber hinge covers from the right and left display hinges.
  12. Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets on either side of the Macbook. Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets on either side of the Macbook.
    • Remove the two 4.2 mm T5 Torx screws securing the aluminum hinge brackets on either side of the Macbook.
    I found these to be very tight and wasnt able to move them with the ifixt screwdriver kit, i had to get a t-handle torx 9 bit to move them
    harveyhalfpint - Yanıt
    Yes they were tight but I managed to shift them with the iFixit screwdriver set
    Steven Fillingham - Yanıt
    This is 1 screw on each side (not 2 on each side). They are circled in red.
    nmackaron - Yanıt
    The T5 in the set I bought from LaptopScreen.com was too big and started to strip these screws. Got an Ace Hardware brand one instead and it worked great.
    Brian Hultin - Yanıt
    Be careful at reassembling. This screw tends to brake if you tighten it too much.
    Mertensa Hens - Yanıt
    These were T4 not T5 size for me
    Praj Basnet - Yanıt
  13. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges. During reassembly, the vertical portion of the bracket should be in line with the aluminum rail in the center of the Macbook. During reassembly, the vertical portion of the bracket should be in line with the aluminum rail in the center of the Macbook.
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    • During reassembly, the vertical portion of the bracket should be in line with the aluminum rail in the center of the Macbook.
    Vorsicht beim Wiederzusammenbau! Diese Schraube ist bei mir am Kopf abgebrochen, als ich sie etwas zu fest hineingedreht habe. Musste das Teil dann notdürftig mit Klebeband fixieren.
  14. Remove the four outer 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case. Some models may use T9 Torx screws rather than T8.
    • Remove the four outer 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    • Some models may use T9 Torx screws rather than T8.
    Does these three screws are the same size? Can i mix use these screws during the installing process?
    Michael Kwok - Yanıt
    On my model, there was a thin piece of translucent plastic covering the left-side outer screws. It peeled off easily. It must be replaced upon reassembly. When removing these two (left-side) screws, a metal assembly securing the antenna wires was released below the screws. It must be replaced before reassembling these two screws.
    Ralph Begleiter - Yanıt
  15. Open the MacBook Pro a little wider than 90 degrees, and place it on end on the table, as shown. While holding the display with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Open the MacBook Pro a little wider than 90 degrees, and place it on end on the table, as shown.
    • While holding the display with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure the display and upper case are balanced and will not fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  16. Grab the upper case with your right hand and rotate it slightly clockwise, toward the top of the display, so the display brackets clear the edge of the upper case. Rotate the display slightly away from the upper case. Pull the display away from the upper case, minding any brackets or cables that may get caught.
    • Grab the upper case with your right hand and rotate it slightly clockwise, toward the top of the display, so the display brackets clear the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Pull the display away from the upper case, minding any brackets or cables that may get caught.
    When replacing the display assembly with a new one, the new hinges may be very hard to move into the 90 degree position. We found it helpful to loop a paperclip into the screw hole of the hinge to facilitate pulling open the hinge.
    Eric - Yanıt
    Yes also found the hinges to be extremely tight, could not move them with from their initial position with fingers, ended up using a pair of pliers to rotate them enough to get fingers under them
    Are there any cheaper replacement screens? If so I need to know. My parents still haven't found out and I don't make a ton of money...
    Haley Hildreth - Yanıt
    The paper clip is a great tip. I also used the spudger flat end under the hinge and the metal side of the case as leverage to push it up.
    D B - Yanıt
    Excellent guide, Andrew! I am an ACMT and when disconnecting the eDP cable, I like to use the pointed ends of two spudgers (Apple calls them ‘black sticks’) to push the connector straight back out of the socket by pushing on its edges. This prevents any stress to the locking bar and also helps to ensure that the connector is disconnected evenly. For reassembly, I line up the connector carefully and once the pins are all lined up and the cable connector partially inserted, I push on the back edges on either side of the connector with the pointed ends of two spudgers, ‘walking’ the connector back into place so that it is even on both sides.
    Also, when disconnecting the camera cable connector from the logic board, I use the same method as above, situating the points of the sticks into the notches on each side of the connector and pushing straight back vs walking it back. I do the same thing when reconnecting the cable, but I ‘walk’ it back as mentioned above with the eDP cable connector.
    Ez Bless - Yanıt
    Also, once I have removed the clutch covers, I remove the two screws holding the metal antenna grounding loop in place (first picture in Step 15 of your guide). I move the loop out of the way and reinstall the two screws just until the heads of the screws make contact with the metal surface of the hinge. I loosen all of the rest of the screws and then tighten them back down just until the screws stop turning (without torquing them). I thoroughly brush off the surface area of the ESD mat where I am going to situate the MacBook for the next step, and then flip it over and open the display 90 degrees. I flip the machine back over and rotate it 90 degrees so that the ‘Apple’ logo on the back of the display lid is facing me, inverted, and the display hinges are much closer to me. After carefully scooting the machine back just until the display makes contact with the edge of the table, I pull the display up toward me to open it fully. I then carefully remove the hinge screws.
    Ez Bless - Yanıt
    For removal, you simply need to lift up slightly on the top edge of the display (possible once the 6 hinge screws have been fully removed) until it has cleared the recesses of the top case. It can then be lifted out without any hassle and you should not need to use any paper clips as mentioned in previous comments. I hope this helps someone; it is knowledge I have gained from following Apple’s Service Guides and experience from having replaced hundreds of displays in a short amount of time. We are an AASP on a university campus, so display repairs are VERY common (from mostly student customers).
    Ez Bless - Yanıt
    Hello everyone! I have problem after display changing. The brightness adjustment doesn’t work anymore. As I fine out its standard situation when you change displays for MacBook. Did anyone know how to fix this issue ?
    Bezromval - Yanıt
    I'm having the exact same issue! Did you find a solution?
    Victor Bui -
    Excellent guide. My IT guys were scared to touch my mac but I did it myself. Thanks to ifixit
    Soul Reaver - Yanıt
    This is an excellent guide. I replaced the screen on my macbook pro 13” retina early 2015. However, I am having some odd behavior from my fixed computer.
    With the lid open, the computer does not seem to boot. However, if I close the lid (after booting or re-booting) the apple logo lights up and when I open the lid fully, the computer operates normally. Any idea what is wrong? I bought the screen replacement second hand on ebay.
    Vivek Chivukula - Yanıt
Sonuç
136 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
382.635 İtibar
543 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
103 Üyeler
9.078 adet Kılavuz yazıldı
28 Yorum
I've been browsing guides to this model and I don't get how in this one on Youtube the laptop looks completely different, although it also claims to be A1502. Either one of them is a different model or I'm really missing something?
https://www.youtube.com/watch?v=lL4gpfcb...
Marina Gorobevskaya - Yanıt
Unfortunately the A1502 number isn't an exclusive model number, several devices share it, the internal differences between them vary. The more telling number is the EMC number, which tends to me more exclusive to unique devices.
Sam Goldheart -
After a closer look they actually seem to be the same, I just got confused by the video being a lot less detailed than this walkthrough. I just replaced the screen of my macbook following this guide (yay!) without any previous experience of fixing macbooks, though I must admit I assembled a few desktops at the dawn of the millennium. The only slight problem I encountered was that the main display cable wouldn't lie flat enough in that corner, it kept sticking out, and even after screwing the lid on the gap at that corner seems to be a tiny bit wider. But the laptop is working anyway.
Thank you Sam for posting this guide! It saved me a lot of time and money. Being in China I bought the display assembly on Taobao for $250US whereas the shop repair estimate that I got was around $400.
If anyone is still having doubts - you can do it!
The guide is very helpful. I managed to replace my screen within 1 hour. I bought my screen from ifixit too! the product is genuine and in good condition although it says that it has been used before! Highly recommended!
henrycwc - Yanıt
Can you replace just the LCD without the clamshell bezel and cables?
rickcostel - Yanıt
Kind of. In most laptops the lcd assembly is a separate unit that can be replaced. In these the top case serves as the lcd assembly.
But you can replace just the lcd polarizer. It is much more difficult than replacing the whole display assembly, as the diffuser panel which is directly behind the polarizer is very fragile.
This video provides a guide on how you can do it: https://www.youtube.com/watch?v=pOS-rjvn...
elec1cele -
I managed to replace the display assembly pretty smoothly and got a cool video out of it! For anyone interested in watching a 2-minute time-lapse version, you can watch it here: (https://youtu.be/BHhpoG-0_oI)
bexoro - Yanıt
Great guide. I was able to complete this in 45 mins with a 4 year old running around the table I was working on. Thanks for a thorough guide. Also bought the screen from ifixit and it looks great.
searnold - Yanıt
Excellent guide! Completed it in about 20 minutes and everything works now!
Vsevolod Kamnev - Yanıt
Great guide, easy to follow.
Replacement display from iFixit had the brackets folded down towards the screen, had to unfold them carefully with pliers.
Take note - the black hinge cover (the bulge on the display assembly) shifts left and right. Make sure to adjust it dead center when assembling. Also make sure to align display with bottom case perfectly before tightening down the bracket screws.
Leonid - Yanıt
good guide replaced my screen no major issues, reattaching the three small cables was the trickiest bit and definitely needed care.
nikolas hodges - Yanıt
To reinstall the new display, do you just follow the instructions backwards?
Tee - Yanıt
A great guide, I spent around an hour to complete removal and install of new display (from iFixit), its cheaper than getting Apple repaired and results in a great quality fix, my daughter is over the moon. I chose the B grade screen and its great, not sure what scratches they are referring to :)
Followed this guide and mine turned out AMAZING. So happy I didn't spend the $500-$600 to have someone else fix it. Literally spent less than an hour to do it all. I would highly recommend buying the needed tools for it .
Shane Hennessy - Yanıt
Am I wrong or it is not possible to replace the front-glass only (without the LCD), on the A1502 Model ? (late 2013) ?
I cannot find the front-glass for this model on the internet... any idea where I can find it ?
Clement Bouchardeau - Yanıt
I need to replace the hinge connected to the display assembly, would that be possible?
Sokar599 - Yanıt
Brilliant guide as usual all done in half an hour. Worth noting that I could not adjust the brightness at first but a PRAM reset sorted that out nicely.
Thank you.
MattOckendon - Yanıt
Just did the same repair.. I am also having display brightness issues but already tried PRAM and SMC resets. Brightness works under Bootcamp but not macOS... any ideas? A third party utility I downloaded allows me to control brightness but I really should be able to use the brightness adjustment keys. Lastly, the 1440x900 display resolution option is gone as well. Stuck with 1024x600 or 1280x800 (default but highest resolution option I have).
Santiago Moreno -
Step 15, Does these three screws are the same size? Can i mix use these screws during the installing process?
Thanks for the very detailed guide. Replacing the screen worked like a charm! But I have a problem: My screen does not turn on. I can hear the start-up sound but the display only shows a black light. By connecting an external screen via HDMI and closing the lid I can boot normally. I tried PRAM and SMC reset, but neither helped. I switched back to the old/half broken screen and it turned on normally. Any idea what I could do next?
Sonopha - Yanıt
Hi, it’s me again. I managed to make it work. It seems that one of the connectors were not connected in the right way. I did not do anything different but switched once back to the old screen and then to the new one again, and it is working. I suspect the one from step 11. I read in other forums that the display connector can be a problem. Thanks for this wonderful guide!
Sonopha -
Super Anleitung. Ich hab es auf den ersten Anlauf geschafft. Danke
Theater Salz und Pfeffer - Yanıt
My display is fine but my cable appear to be broken. It only works at certain angles. Is there any way I can avoid replacing the whole screen?
Jerry G. - Yanıt
Excellent, thought I’d killed my screen by dropping the ‘book, but all I needed to do was reseat the main cable. THANKS!!
Benspamm - Yanıt
This is a great guide! Managed to complete removing the display assembly in less than 20 minutes. Any leads on how to fix/replace a broken lcd? Can that be done? or does one need to replace the entire display assembly?
Mitalee Parikh - Yanıt
How can I know if my laptop would need a t9 or t8 for step 15??
Ali Asadian - Yanıt
Many thanks for the detailed, careful instructions - and especially the clear, useful photos. Saved me a lot of money, and a lot of headache. Repair was clear and straightforward.
Hi,
can I replace an damaged display of a MacBook Pro 13” late 2013 with a display from the early 2013 version?
I compared the high-def pictures of each cable connection and they seem to be identical, or am I wrong?
Thanks for the help.
Cheers
L
Hans Wurst - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 58
Son 7 Gün: 321
Son 30 Gün: 1,736
Her zaman: 119,093
