Giriş
Use this guide to replace the left speaker.
When operating normally, during most of the guide it will be on the right, as your laptop will be upside down.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$16.96
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
87 farklı kişi bu kılavuzu tamamladı.
17Kılavuz Yorumları
Pretty much, there's another cable to disconnect, but we have a whole guide for the right speaker, too! Best of luck!
Hi! Are the L/R speakers compatible with the 13" Early 2015 models?
Great guide. I was able to dismantle the speaker and fixed the blown left speaker. Fit it back and it worked. Now, i’ll do that for the right speaker.
