Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:Magnetic Project Mat$19.95-
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
Remove the following screws securing the left speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
83 farklı kişi bu kılavuzu tamamladı.
16 Yorum
Pretty much, there's another cable to disconnect, but we have a whole guide for the right speaker, too! Best of luck!
Hi! Are the L/R speakers compatible with the 13" Early 2015 models?
Great guide. I was able to dismantle the speaker and fixed the blown left speaker. Fit it back and it worked. Now, i’ll do that for the right speaker.
