Ana içeriğe geç
MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 2, 1 resimden 1.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 3, 2 resimden 2.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, Battery Connector: adım 4, 1 resimden 1.
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 5, 2 resimden 2.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 6, 1 resimden 1.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: adım 7, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: adım 7, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement, AirPort Board: adım 7, 3 resimden 3.
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  8. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 8, 1 resimden 1.
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  9. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 9, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 9, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 AirPort Board Replacement: adım 9, 3 resimden 3.
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.892 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 63
Her zaman: 27,120
