Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the lower case.
Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
18 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Do i have to hear some "click" noise when reconnecting the plastic clips? I did gently push the middle of the lower case, but the clips did not reconnected (it was still easy to remove the lower case). Hence i just put screws back, and then little bit strongly push the lower case again, but there was no "click" noise eithe ... However, the bottom case is completely flat, so i suppose it is ok...
