Ana içeriğe geç
MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement
Neye ihtiyacın var
    1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Lower Case: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      Magnetic Project Mat
      $19.95
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 2, 1 resimden 1.
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 3, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 3, 2 resimden 2.
      • The lower case is connected to the upper case with two plastic clips near its center.
      • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Battery Connector: adım 4, 1 resimden 1.
      • If necessary, remove the plastic cover adhered to the battery contact board.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 5, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 5, 2 resimden 2.
      • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
      • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 6, 1 resimden 1.
      • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: adım 7, 3 resimden 3.
      • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
      • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 8, 2 resimden 2.
      • Pull the DC-In board connector straight out of its socket on the logic board.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 9, 1 resimden 1.
      • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
      • You may need to gently push the display cable out of the way to expose the screws.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 10, 3 resimden 1. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 10, 3 resimden 2. MacBook Pro 13" Retina Display Mid 2014 MagSafe DC-In Board Replacement: adım 10, 3 resimden 3.
      • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.765 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
38.652 adet Kılavuz yazıldı
7Kılavuz Yorumları
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
lewismacqueen - Yanıt Paylaş
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Brian Smithson - Yanıt Paylaş
Thank you ...just what we need !..
Mark White - Yanıt Paylaş
Did anyone else lose the display to their MacBook Pro mid 2014 after following this repair?
Vance - Yanıt Paylaş
yes I just did and wonder what you did to solve this?
Kaleem - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 94
Her zaman: 18,955
