Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:Magnetic Project Mat$19.95-
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Pull in the direction of the cable, parallel to the logic board. Do not pull up.
Pull the DC-In board connector straight out of its socket on the logic board.
Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
28 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Thanks very much, took me 10 mins, A nice cheap and fast repair for my damaged MagSafe socket
Thank you for your guidance! Spent $30 on tools as opposed to hundreds and made a simple repair
Thank you ...just what we need !..
