Ana içeriğe geç
MacBook Pro 13" Touch Bar 2018 Trackpad Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: adım 1, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: adım 1, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: adım 1, 3 resimden 3.
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Yanıt
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Yanıt
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Yanıt
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Yanıt
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Yanıt
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Yanıt
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Yanıt
    Not able to do that with damaged screen
    richardjgreen - Yanıt
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Yanıt
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Yanıt
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Yanıt
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Yanıt
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Yanıt
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Yanıt
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Yanıt
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Yanıt
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Yanıt
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Yanıt
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Yanıt
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Yanıt
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Yanıt
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Yanıt
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Yanıt
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Yanıt
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Yanıt
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the pentalobe screws: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Open a gap using a suction cup: adım 3, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Open a gap using a suction cup: adım 3, 2 resimden 2.
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Separate the clips: adım 4, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Separate the clips: adım 4, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Separate the clips: adım 4, 3 resimden 3.
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 5, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 5, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 5, 3 resimden 3.
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
    Recommend being very careful on this step and the following step when using any opening tool to always keep the “pointy end” up when prying, especially about 40mm up the side, to avoid completely destroying the speaker diaphragms.
    just chris... - Yanıt
  6. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 6, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 6, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 6, 3 resimden 3.
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 7, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 7, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 7, 3 resimden 3.
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
    I am sure that there are two snap lock things is the middle as well, not only on the side, is there a way to open that in a correct way too?
    Jack Jin - Yanıt
    I found using the suction cup tool to help slide the cover helps.
    Clem Wang - Yanıt
  8. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the lower case: adım 8, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the lower case: adım 8, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the lower case: adım 8, 3 resimden 3.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Uncover the battery connector: adım 9, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Uncover the battery connector: adım 9, 2 resimden 2.
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 10, 2 resimden 2.
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 11, 2 resimden 2.
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    Be very careful here. It is easy to break the whole connector off the battery board, which is what I did. Luckily the connector is part of the replacement battery, so you just need to remove the connector from the cable. The pictures here should provide more detail so you can see better what is going on.
    Mark Hayden - Yanıt
    thanks a lot !!!!! great help :)
    der gute Geist - Yanıt
  12. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 12, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 12, 2 resimden 2.
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
    As simple as this step might seem, the golden leads will disapper the moment you remove it as it has some adhesive under the black strip that covers it. Ensure you peel it back enough to display the golden leads after swapping the batteries out.
    Harish Prasanna - Yanıt
    Your battery may come with this ribbon cable. In that case, disconnect the other end.
    bencottrill - Yanıt
  13. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 13, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 13, 2 resimden 2.
    • Fold the battery board data cable to the side and out of the way.
    I don't recall removing this cable from the laptop. I see that when actually putting the new battery in, the cable is attached already where it was detached and the right end needs to be reconnected.
    durphym - Yanıt
    unfortunately the instructions to removing this cable are absent and I tried to pry the tab up instead of out and I damaged my board. Now no battery will work but it still functions with only with power cord. So be careful!
    Laloyd - Yanıt
  14. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 14, 1 resimden 1.
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disconnect the battery: adım 15, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disconnect the battery: adım 15, 2 resimden 2.
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
    To completely avoid accidental contacts I recommend to wrap this connector in a piece of paper and hold it in place with tape.
    Do not put tape directly on the contact underside, as that may leave some glue that would affect the contact conductivity.
    Sergio Ballestrero - Yanıt
    I put a piece of tape on the underside of the connector (sticky side up) to insure against accidental battery contact. If you put tape on the logic board side of the connection, some insulating padding material might accidentally stick to the tape when the tape is removed during reassembly.
    W. Smith - Yanıt
  16. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the trackpad connector screws: adım 16, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
    On my 13" 2019 Macbook Pro, these were T5, not T3.
    Evan Charlton - Yanıt
  17. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 17, 1 resimden 1.
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  18. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disconnect the trackpad: adım 18, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Disconnect the trackpad: adım 18, 2 resimden 2.
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
    Thank you for the hairdryer suggestion. Worked out for me.
    Lorenzo - Yanıt
  19. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Heat the trackpad cable: adım 19, 1 resimden 1.
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  20. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Peel up the trackpad cable: adım 20, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Peel up the trackpad cable: adım 20, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Peel up the trackpad cable: adım 20, 3 resimden 3.
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
    the 8 screws are T3
    Nancy Benovich Gilby - Yanıt
    No they are in fact T5.
    Lorenzo -
  21. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement, Remove the trackpad screws: adım 21, 1 resimden 1.
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
    Heating the wrist-pad area and carefully using a plastic card to separate the adhesive allowed me to remove the battery without needing to use the solvent or removing the track-pad. No need for taping the speakers.
    johann beda - Yanıt
    I attempted as well the shortcut with no solvent and no track-pad removal. Also, I didn't apply heating. Everything was totally fine yet a bit risky. In such conditions it is very hard not using the spudger flat tip to lift the battery packs. Well, I highly recommend NOT using the spudger on the two central packs. In fact, it would be extremely easy to destroy surface mounted components on the track-pad board which would be accessible through the metal frame holes under the packs (see pics along this guide). Plastic cards are always fine. Next time, I would probably avoid spudger and introduce floss as shown in Picture 34 below.
    bc_ -
  22. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 22, 2 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 22, 2 resimden 2.
    • Swing the display open slightly to access the trackpad.
    • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
  23. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 23, 3 resimden 1. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 23, 3 resimden 2. MacBook Pro 13" Touch Bar 2018 Trackpad Replacement: adım 23, 3 resimden 3.
    • Remove the trackpad assembly.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
    • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
    Should include instruction to wedge thin paper one every side of the trackpad to keep it aligned during reinstallation. Without the wedges, the trackpad would come out misaligned, which might damage it from excessive friction. Kapton tape might also work, didn't try it though.
    These instructions were standard for Unibody models in the past, don't know why it wasn't included here.
    garegin - Yanıt
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Tarun Thiruma
35.268 İtibar
134 adet Kılavuz yazıldı
2 Yorum
How is the trackpad cable removed? is it simply adhesive or solder?
Scott Venable - Yanıt
Dude - really well done guide - went very easily.
A tip on how to put the trackpad cable on would be good, it was trial and error.
Can’t believe how easy that was to do!
JAS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 42
Son 30 gün: 224
Her zaman: 9,779
