Giriş
Use this guide to replace a touchbar on an A2289 Macbook Pro 13" Mid 2020.
Be mindful to keep all screws and brackets organized. This will keep from damaging sensitive components by accidently screwing the wrong size screw in.
Neye ihtiyacın var
To begin, we will need to remove 6 total screws
2x 6.9mm Pentalobe P5
2x 5.5mm Pentalobe P5
2x 3.5mm Pentalobe P5
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
After the screws are removed, grab a suction cup. We used iFixit's Heavy Duty Suction cup.
Place the suction cup towards the bottom of the Macbook
Pull up on the suction cup; Creating about 0.15in worth of space from the panel and the Macbook.
Bu adımda kullanılan alet:iFixit Opening Picks (Set of 6)$4.99
While creating the gap between the Macbook and the back panel, insert an opening pick into the gap about 0.2in.
Move the pick towards the left side of the Macbook and around the corner edge.
Bring the pick up towards the top of the Macbook
Once you reach about the middle of the Macbook, you should hear a click. This is good! You have now unhooked part of the back panel.
Insert your fingers in-between the back panel and Macbook and pry upwards to unhook the middle hook keeping the back panel connected to the Macbook
Grip the back panel with one hand
Grip the Macbook with the other hand
And pull the left side of the back panel AWAY from the HINGE side of the Macbook
Repeat this with the right side of the Macbook
Bu adımda kullanılan alet:Tweezers$3.99
Locate the battery connector cover
Take a pair of tweezers and gently remove the plastic cover from the Logic Board
Locate the small flex cable covering the battery terminal
Take a pair of tweezers in one hand and pull up on the plastic flap
Take the hook end of a Halberd Spudger in the other hand and gently pry up the retaining flap on the battery cable ZIF socket
Take your tweezers and pull on the plastic cover away from the ZIF socket to remove the flex cable from its socket
Bu adımda kullanılan alet:Spudger$3.99
Remove the 3.8mm Torx T5 screw from the battery connector
Take the flat end of a spudger and pry up the battery connector to a 90° angle
Locate the left hinge cover
Remove 2x 2mm Torx T3 screws securing the hinge cover to the Macbook
Take a pair of tweezers and remove the hinge cover
Locate the right hinge cover
Locate your LCD flex cable towards the top of the Macbook
Locate the bottom cover plate
Remove 2x 3.2mm Torx T3 screws securing the bottom cover plate to the MacBook
Take a pair of tweezers and remove the brackets
Locate the top cover plate of the LCD flex cable
Remove 2x 1.8mm Torx T3 screws securing the top cover plate to the Macbook
Take a pair of tweezers and remove the now free cover plate
Take the flat end of a spudger and gently pry up the LCD flex cable from its port
Lift LCD flex cable up and away from the Macbook
Locate the left LCD screen spring
Remove 2x 4.1mm Torx T3 screws securing the spring to the MacBook
Locate the right LCD screen spring
Locate the antenna towards the top of the Macbook
Remove 12x 1.2mm Pentalobe P2 screws securing the antenna to the MacBook
Locate the LCD board towards the top of the Macbook
Remove 4x 3.4mm Torx T5 screws securing the LCD board to the MacBook and to the antenna
You should now be able to remove the antenna from the Macbook.
Gently pry & pull away the antenna cable from the Macbook while routing it's cable through their hole. Take care here, as the antenna sockets can be ripped from the board easily.
Locate the left LCD screen hinge
Remove 2x 4.5mm Torx T9 screws that secure the hinge to the MacBook
Locate the right LCD screen hinge
Place MacBook at the edge of your work bench and let the screen overhang
Locate and remove the remaining 2x 4.5mm Torx T9 screws securing the 2 hinges to the MacBook
Bend the LCD screen slightly towards you
Gently pry up the LCD screen from the Macbook, while guiding the hinges out of their divots
Locate the power button flex cable bracket towards the top left of the MacBook
Remove 2x screws securing the bracket to the MacBook
1x 5mm Torx T3 Screw
1x 1.4mm Torx T3 Screw
Locate the trackpad's flex cable bracket towards the middle of the Macbook
Remove 2x 1.9mm Torx T5 screws securing the bracket to the Macbook
Then take a pair of tweezers and remove the bracket
Using the flat end of a spudger gently lift the connector from its socket
Locate the right speaker flex cable bracket
Remove 2x screws securing the bracket down to the Logic Board
1x 3.7mm Torx T5
1x 2.6mm Torx T5
Take the flat end of a spudger and carefully pry up the flex cable from its socket
Locate the left speaker and touch bar bracket
Remove 3x 1.4mm Torx T3 screws from the bracket
Take the flat-end of a spudger and gently pry up all 3 flex cables from their sockets
Locate 8x flex cables connected the logic board
For each flex cable, pull up on their plastic flap with a pair of tweezers
Take the hook end of a Halberd Spudger and gently pry up the retaining flap on the ZIF socket of each cable
Take your tweezers and pull on the plastic cover to pull each cable away from the ZIF socket to remove the flex cable from it's socket
If any of the plastic flaps break off don't worry! You can use a combination of your spudger and tweezers to gently pull out the flex cable from it's respective socket
Locate and remove 5x Logic Board Screws
3x 3.4mm Torx T5 screws
1x 3.6mm Torx T5 stepped screw
1x 3.3mm hex standoff (3mm drive)
During Reassembly: It may be difficult to screw the top left logic board standoff back in. If you are finding it hard to do this, take the 1.4mm screw that we removed to remove the power button bracket and screw it into the top left logic board standoff. Afterwards, take the now "cyborg" screw and screw it into the logic board.
Bu adımda kullanılan alet:Halberd Spudger$2.99
Take the hook end of your Halberd Spudger and gently pry up the top left corner of the logic board
Now remove the logic board from the Macbook
Locate the touchbar flex cable mess towards the top right of the Macbook
You will be removing a total of 3 screws to release this cabled mess from the frame
2x 2.4mm
One of these are "hidden" by a small pad. Take a pair of tweezers and remove this pad to access the screw head
1x 1.7mm
These brackets that keep the cabled mess down and attached to the frame are adhered to the cabling
Remove these brackets from the flex cabling mess
Bu adımda kullanılan alet:iFixit Adhesive Remover$19.99
There are 2 methods that we can take towards removing this annoying touchbar. We went ahead and performed what we thing is the harder method.
Method 1: Take 2 tweezers or handles and wrap very thin wire around them. Then pull the wire underneath the touchbar LCD gently while being careful not to damage the keyboard
Method 2: What we did. Remove the touchbar digitizer first by prying it up and off the touchbar LCD. Then use a combination Adhesive Remover and a Technician's Razor Set to remove the touchbar LCD.
Take a Halberd Spudger and insert the knife end right underneath the plastic of the digitizer
Run the Halberd Spudger along the edge of the touchbar digitizer
The digitizer should separate surprisingly easy.
Feed the Touchbar digitizer cable through the hole and remove the digitizer
Bu adımda kullanılan alet:Technician's Razor Set$14.99
Take a technician's knife and start prying away the LCD of the touchbar.
Locate the cable side of the NEW touchbar
Locate the detachable end of the flex cable and use the flat-end of a spudger to disconnect the larger portion.
Locate the little hole near the left side of the Macbook and feed the touchbar flex cables through it.
Locate the larger bracket and place it down in it's spot. Reference the images for assistance.
Place something heavy enough to keep the flex cables back but light enough not to damage them (Ex: metal spudger)
Remove the blue adhesive protector from the touchbar digitizer cable
Align cable to bracket and press the flex cable firmly down onto the bracket
Remove both blue adhesive protectors
Take touchbar LCD flex cable and place it against the touchbar digitizer flex cable
Press firmly on the flex cables to adhere the 2 together
Locate the second bracket and place it in it's correct spot. Reference the photos and step 36 for assistance.
Screw down the bracket using it's screw. Reference step 36.
Place a small strip of adhesive to the bracket. We used basic Tesa tape
Remove the white protective top of the tesa tape
Remove the blue protective film on the flex cable
Take the flex cables and bring them down to the bracket
Press the flex cables firmly onto the bracket to adhere the flex cables to the new bracket
Carefully lift the touchbar assembly up and out of it's little crevice
Remove the black adhesive protector from the touchbar
Carefully align the touchbar to it's crevice
Once perfectly aligned, place the touchbar into it's crevice and push firmly but not hard on the touchbar to finalize it.
To reassemble your device, follow these instructions in reverse order starting with Step 35.
We here at Smart Cloud hope your project goes smoothly and without a hitch. However, things happen and we want to make sure you know we are here to help if needed. You may contact us for assistance and we will provide support or repair options per request. Good luck and have fun.
10 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
hi, sorry to bother you, but wouldn’t it be possible to remove the touch bar without removing the screen and the motherboard?
It seems that isn’t necessary to remove all three screws at step 36, but just the upper left one which can be reached even with the motherboard in place, hope you will be able to give me an answer, thanks for your work
Giacomo,
Excellent question! We want to remove the screen to protect it from any acetone that we use to help release the adhesive of the touchbar. The device is also a lot easier to handle when the screen is removed.
All the screws described in step 36 are necessary to remove as they are all attached to the touchbar cables.
It is also required to remove the Logicboard to properly disassemble and reinstall the touchbar cables without worry of damaging them. You MIGHT be able to do it without removing the logicboard, but you run the high risk of damaging the new touchbar cables during the install (emphasis on the word might).
In my honest opinion, sometimes taking the extra steps and going slow with it is worth it.
Thank you @smartcloudllc for your help. I have actually worked with several iPhones, but this seems to be on an higher level (of risks and costs). However, thank you so much, the tutorial is perfect on every aspect.
This was thorough and informative. As a professional I try to do this kind of stuff myself, but as an individual with my personal device, I'm not doing that. You never know what this work will look like until you see the whole thing through for your particular model and wow, this is nuts. I thought upgrading to SSD storage on my 2009 iMac was difficult.
