Giriş
If your trackpad is broken or needs to be removed for easier access to the battery, follow these steps.
For your safety, discharge your MacBook Pro's battery below 25% before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Neye ihtiyacın var
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.8 mm screws
Two 5.3 mm screws
Two 3.4 mm screws
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Remove the lower case.
Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Use a T5 Torx driver to remove the two 1.9 mm screws securing the trackpad cable connector bracket.
Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
2 Yorum
Wichtig, ich habe das MacBook 3 Mal noch zerlegt und wieder zusammen gebaut, weil es nicht booten wollten. Im Endeffekt habe ich alles richtig gemacht, aber nachdem der Akku getrennt wurde, muss es kurz am Strom angeschlossen werden, damit es booted...
Ein Tip für die kleinen scheiben, die zwischen Ramen und Trackpad liegen habe ich leider nicht. Ich habe sie beim montieren hingelegt und das Trackpad vorsichtig platziert. Ich gehe davon aus, dass sie gut liegen.
Tip 2: wenn man das neue Trackpad eingesetzt hat, die 10 Schrauben aus Schritt 20 nur leicht anziehen und dann dass Trackpad in seine Position schieben, sonst klingt es sehr hohl und macht keine Freude. Wenn es richtig in Position ist(bei mir war das ein Einrastgeräusch) dann erst die Schrauben festzeihen.
