Ana içeriğe geç
Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
MacBook Pro 13" Unibody 中期 2009 电池更换
Neye ihtiyacın var
  1. MacBook Pro 13" Unibody 中期 2009 电池更换, 后壳: adım 1, 1 resimden 1.
    • 移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
    • 7个3 mm Phillips螺丝
    • 3个13.5 mm Phillips 螺丝
  2. MacBook Pro 13" Unibody 中期 2009 电池更换: adım 2, 1 resimden 1.
    • 轻轻提起后壳然后推向电脑的后方来松开卡舌。
  3. MacBook Pro 13" Unibody 中期 2009 电池更换, 电池: adım 3, 1 resimden 1.
    • 拆下将电池固定在顶壳的三点螺丝。
    • 1个 5.5 mm 三点螺丝。
    • 1个13.5 mm 三点螺丝
  4. MacBook Pro 13" Unibody 中期 2009 电池更换: adım 4, 1 resimden 1.
    • 使用撬棒扁平的一段来将电池的连接器从逻辑板的插座中分离开来。
  5. MacBook Pro 13" Unibody 中期 2009 电池更换: adım 5, 1 resimden 1.
    • 将电池从顶壳中移除。
Sonuç
要重新组装您的设备,请按照本指南的相反顺序进行操作。
727 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
en zh
85%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
50 Yorum
My laptop wouldn't believe the battery was new until I reset the SMC as well ( http://support.apple.com/kb/HT3964 ).
penguinofdeath - Yanıt
Perfect! I didn't want to wait for the Tri-wing screwdriver to ship, so I gave it a try by wedging a FH 1 in between two of the wings. It worked well to unscrew, but you must be very careful when resetting the screws that hold the battery. If you get them started with your finger (a little pressure with your thumb pushing straight down will get the job done) then you can do a few final turns with the FH 1. If you try to start resetting the screws with the off-center-FH1-workaround, you will strip the screw! Keep the screws centered and don't force anything.
Laurence Benson - Yanıt
worked like a charm. my old battery had bulged and made it so that the track pad would not click :-( replacing the battery did the trick.
statprof - Yanıt
My local Apple Store wants $179 plus tax to change this battery, AND I have to leave my laptop for "a couple of days." This is one store that clearly doesn't get it (Cherry Creak Mall, Denver). Thus, a DIY fix is mandatory... but, they won't sell just the battery.
channonholiday - Yanıt
iFixit sells the battery you need for $119 ([bağlı ürün eksik veya kapalı: IF163-019]), and once you get it, doing the replacement shouldn't take more than 30 minutes, even if you've never done a repair like this before.
Taylor Arnicar -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 118
Son 30 gün: 587
Her zaman: 572,274
