Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace a dead hard drive.
Videoya Genel Bakış
  1. Remove the following ten screws:
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
    Does void the warranty?
    jfondeur - Yanıt
    No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
    oakdragon12 - Yanıt
    How much weight can I save by removing the optical drive?
    gunes314 - Yanıt
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
    Carlos Duarte do Nascimento - Yanıt
    Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
    Seji the veggie -
    What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
    Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
    pmhparis -
    The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
    While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
    Dan -
    I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
    John Adam Wickliffe - Yanıt
    Hey guys,
    this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
    I posted some pictures on your facebook page..
    renatumb - Yanıt
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - Yanıt
    Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
    kschmesk - Yanıt
    Totally agree!! I used the #00 screwhead for 7 out of the 10, but for the remaining tricky ones I used the #0 screwhead and it helped me out. I was so worried I would strip the tiny screw, but this comment saved me!
    Juliana Mak -
    I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
    Alex - Yanıt
    The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
    . Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
    I got round it by using the camera cable from the old set and cutting off the new one
    brian whittle - Yanıt
    Hello MacWorld,
    Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
    wer 10/5/15
    tayseer999 - Yanıt
    I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
    ForumHermit - Yanıt
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - Yanıt
    on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
    Maximilian Klotz - Yanıt
    I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
    gilded yak - Yanıt
    Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
    Jack - Yanıt
    I have the same question. What is the difference between shouldered and not? So hard to see any difference…
    Michael Wilkens -
    I’ll second that. I could never find them being different.
    otetz -
    Same here… I could not notice hte difference. Anyone at iFix would like to comment?
    LDS -
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - Yanıt
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
    Stephen Smith - Yanıt
    A screw does not come out, how can I get it out? Many thanks in advance for your help
    Wilder Torres - Yanıt
    Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
    airshack - Yanıt
    when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
    this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
    Matt - Yanıt
    It seems to me the yellow and orange screws are the same
    Luca Giancarli - Yanıt
    If you look closely, the four front screws (with the yellow circles) have a short unthreaded section under the head. The orange keyed screws are threaded all the way up.
    Raymond Ives -
    The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
    Don Cely - Yanıt
    Two screw types:
    ______________________________
    Shouldered Unshouldered
    xxxxxxx……….xxxxxxx
    ..xxxxx……..….…….x…….
    …..x……..…...……….x…….
    …..x…………....……..x…….
    El Crashitan - Yanıt
    If you are following this guide to upgrade to a better drive and want to keep your system and data intact I highly recommend first following the guide to Clone an Existing Drive using the recommended free SuperDuper!. That process was a breeze and gives you confidence that the new drive will come up looking exactly the way it did when you started.
    Patrick Langvardt - Yanıt
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - Yanıt
    I did this last weekend, and definitely, a Phillips #000 screwdriver is required (not a Phillips #00!)
    Javier Campos Delgado - Yanıt
    WIll this card be good with MacBookPro 17 inch 2011
    Zafar Ali - Yanıt
    I just followed this guide and it really helped me install a replacement cable and a new Samsung 860 EVO 500gb SSD in my aging MacBook Pro 13 A1278 MID 2012. It’s performing like a new machine now! The guide worked fine, but I’m curious why this HD cable costs €45 on Ifixit’s webshop, and only €13 on Amazon.de (I live in Europe)? The Amazon purchase also included two screwdrivers and a spudger.
    Jeff Baker - Yanıt
    I found out that one way to reduce the chance to loose screws is to leave them in their holes of the lower case right after unscrewing them. In fact, you can put the lower case back in place with all but one screws in place. The only one that I ever needed to put apart was the long one at the top right in the picture (the one that goes close to the display data cable underneath the lower case). Hope this help others! and you stop wondering about shouldered versus not shouldered short (3.5mm) ones :-)
    LDS - Yanıt
  2. Use your fingers to pry the lower case away from the body of the MacBook near the vent. Remove the lower case.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
    If the black vent window that is attached to the back cover becomes loose what kind of glue should be used to attach it again, thermal paste or super glue?
    Thanks for your help.
    Mikell - Yanıt
    bonjour cette truc ça marche au mac Brook pro Retina ou pas?
    Shi Feng - Yanıt
    Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
    Claire Rapp -
    Merhaba, trackpad değişimi ve ayarlaması için tornavidaya ihtiyacım var, bu konuda yardımcı olabilir misiniz acaba? Ne tür bir tornavidaya ihtiyacım var ve nereden bulabilirim acaba?
    Volkan Ogul - Yanıt
  3. Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board. It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    Is this step of removing the battery connector required?
    manodh - Yanıt
    yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
    khull -
    Sooo the track pad is under the battery...you kind of have to remove it to get to the track pad.
    stiknrudder -
    This step is not really required. Apple does not recommend it.
    Steven Layton - Yanıt
    My Battery does not get recognized after i disconnected it, screw this site!
    Diego Hernandes -
    Did you properly ground yourself to the case before putting the spudger to the connector/logic board? Did you use a spudger or something else that is non conductive...or did you use a flat blade metal screw driver instead and compound your error by not grounding yourself before touching the logic board? All kinds of variables here but the bottom line is iFixit provided you a guide to fix your computer. Lots of others have followed this guide without trouble. Your battery issues are not their fault. They did say this guide was moderate difficulty...maybe it's just a little beyond your skill level. We should all know our limits!
    stiknrudder -
    Rather than be careful of the corners of the connector i would say don't use the spudger anywhere near the corners. While the corner looks like the obvious place to begin to pry it up from, it will break. Levering from the sides as the instructions suggest works well.
    ausmkv - Yanıt
    wonder why apple does not recommend it?!
    Peter - Yanıt
    I would recommend it, one careless short and the whole board is dead......
    John - Yanıt
    simply remove the battery rather than disconnecting the cable
    toiu - Yanıt
    What do you mean by "remove the battery"?
    Anrothan -
    Don't know what the deal is with the battery, but this IS a necessary step to keep from frying the logic Board if you accidentally touch something and short it out. I did this step every time during my troubleshooting and The battery was ALWAYS recognized by the system the next time I turned the MBP on. So be safe and don't fry your logic board in the process...
    fasthans - Yanıt
    Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
    aekinaka - Yanıt
    Installed/upgraded 4gb RAM to the system maximum 16gb and installed a 500 gb SSD today....DID NOT disconnect the battery cable....no issues at all when I powered back up. Then did a clean install of OSX Yosemite....next I used a time machine backup to put all my stuff back on the new HD. From start to finish it took about 4 hours. Macbook boots up right at 16 seconds now.
    MacProUser - Yanıt
    Easiest to use two spudgers, one on each short end, I found.
    Simon Mundy - Yanıt
    I took off th Airport /Bluetooth connectors but the number J3 connector is broken and so where can i buy J3 connecter for the Airport/bluetooth board
    Zeerachen - Yanıt
    Its a lot easier and safer (corner wise) to pry it using the flat side of the black spudger directly in front of the connector (don't go/use the corners) very easily you will be able to pry it further by inserting the spudger into a better and thicker plastic section of the connector
    Ed Oliver - Yanıt
    DON'T remove the Battery Cable, you risk the battery NOT being recognised when you start the Mac up again, or breaking it!! More to the point, APPLE DOES NOT RECOMMEND THIS, so don't do it! I Installed 2x 8GB ( 16Gb total) of Crucial Mac RAM at 1333Mhz for my Late 2011 MacBook Pro, and it works beautifully, fully recognised and working well. I followed these instructions, but as Apple didnt recommend disconnecting the battery, I skipped this step, and as well as taking less time, nothing was damaged or broken, and everything works perfectly!!! Just make sure that you DISCHARGE ALL STATIC ELECTRICITY FROM YOUR HANDS, by touching a metal surface in the Mac. Apple recommends the edge of the Optical Disk Drive ( Big silver thing ) before touching any parts. Also, Take care removing the RAM out of its packet, DO NOT touch the Gold connectors, and hold the RAM by the edges. Finally, be PATIENT, GENTLE and it should all go perfectly. I managed it first time, with no technical ability, so follow my advice. Good luck!
    Bradley Marks - Yanıt
    Followed the tuto Step by step. Disconnected the battery (quite easily).
    No problem when I lit the Mac on again. Battery's here, date's right.
    nichoferr - Yanıt
    Switch off your Mac and continue without disconnecting the battery. Don't know how it will switch on by itself.
    Mfernandez - Yanıt
    This comment made me think that disconnecting the battery was no point at all, because really - how would the computer be able to switch on by it self. So... I had my mac flipped around and was fiddling with the last part of the guide when I all of a sudden hear the start up sound! Don't know how and why it did. I turned it around with it guts open and guts hanging out. Screen was on. I forced it to shut down by keeping the power button down. Turned it back and first thing removed the battery cord.
    Luckily the computer started up just like normal. But hearing that sound was just too scary.
    BTW I had been cautious to de static myself multiple times.
    wassberg -
    Definitely do this step. It's an easy disconnect anyway and also easy to reconnect later.
    I removed the battery cable for the repair. When I plugged in the MagSafe adapter after the repair, the Mac turned on automatically without pressing the power button and I was a bit worried, but after a restart everything worked fine again. I did have to reset date and time in Preferences. The battery was recognized OK.
    Raymond Rinaldi - Yanıt
    Okey, I skipped this battery disconnection part. Did not do anything like this before in my life, changing the cable was super easy!
    Marijke de Vries - Yanıt
    The official Apple guide to replacing the RAM says nothing about disconnecting the battery but it does recommend touching metal inside to discharge static. https://support.apple.com/en-us/HT201165
    B T - Yanıt
    I always do this when working on MacBooks (over ten years) and it never caused an issue. Don’t worry about this step as removal of the battery connector is simple. This particular connector is pretty much goof-proof as it won’t break. I’m fairly aggressive and just pop it off whenever I’m working on the Macbook Pro.
    airshack - Yanıt
    Hello!
    Do I really need to use a spudger tool? Can’t I just use like two plectrums for guitar? xD
    Myzcio - Yanıt
    I have a late 2011 MacBook Pro 13in and did not disconnect the power from the battery. I upgraded from 4gb to 16gb and worked perfectly. Just make sure to power it down and be gentle. It was super easy and quick, and I feel a significant boost in performance. Cant wait to install my 1TB SSD Samsung 860 next!
    Rock Hash - Yanıt
    Be patient on disconnecting this one. It worked for me step by step, little by little.
    Phil Wagner - Yanıt
    u can use 16GB DDR3 @ 1600mhz. intel says 16 @ 1333, and apple 8.
    apple will solder even the folders to the background for to sell you the “open” or “move to the trash” command. if the battery is not removable, its not a casuality…. u can be sure
    Oscar Sanchez - Yanıt
    Would draining the battery (by using the machine until it runs out of power) do the trick for this? Seems it would be less risky than potentially damaging the connector/cable during disconnection for example.
    moshimoshi - Yanıt
  4. Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    What are the changes of it broke when i bend it?, after i disconect it does not work anymore
    Diego Hernandes - Yanıt
    The guide worked perfectly, as it has in the past (our family has three Mid-2012 Macbook Pros that have been separately upgraded with RAM and SSD).
    The PH00 screwdriver fit perfectly.
    One note on getting the screws to seat easily and thread perfectly...always turn them gently a couple turns to the left (CCW or Anti-Clockwise) until you hear a small click. That's where the threads will grab. Works with any screw, but when threads are fine, this will help ensure that the screw is at the correct angle and will grab and seat perfectly.
    Great guides. Thanks!
    timgunkel - Yanıt
    Got RAM in but only one slot is working and now I can't remove! The RAM won't pop up like before and tabs don't seem to do anything. Please advise.
    Sal Ergrapes - Yanıt
    I put some tape between the connector and socket while working on the drive.
    That's a good tip
    Anrothan -
    Followed the advice and right as I was installing the replacement fan , the socket broke right off the motherboard.
    Ian Thal - Yanıt
    One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
    lelandjordon - Yanıt
    does the battery connection need to be removed? I only ask as other videos etc have not shown this step.
    Darren Rose - Yanıt
    Très bonnes explications. Concernant le débranchement de la batterie, faute de “smudger”, on peut le faire tout doucement avec le bout des ongles (s’ils ne sont pas coupés trop à ras, LOL), et surtout ne pas tenter de le faire d’un coup: il faut y aller tiers de mm par tiers de mm. Le retrait des anciennes mémoires n’est pas facile non plus, car on a très peu de place pour manœuvrer, là encore il faut y aller petit à petit, avec les plus grandes précautions! La barrette située le plus profond doit être soulevée assez fortement dans sa partie libre pour pouvoir être extraite de son étroite cuvette et ce n’est pas simple. Le remontage est nettement plus simple que le démontage. Il faut surtout faire très attention à ne pas confondre les petites vis à épaulement avec celles qui n’en ont pas. Je conseille, avant de remettre le couvercle de fond du Mac, de faire un essai de redémarrage pendant une minute ou deux pour bien voir si tout est OK.
    Lionel Colbere - Yanıt
  5. Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
    These were Philips #0 screws in my computer.
    Church Tucker - Yanıt
    Yup I think should be #0. Fits better.
    ezkay -
    FYI my used Mac didn’t have the bracket or screws. 3D printed the bracket someone did (it’s on Thingiverse), M2x10mm screws were short but worked.
    sbierly - Yanıt
  6. Remove the hard drive bracket.
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
    Don't miss this step: I almost did and of course couldn't get the disk out until I looked at the video !
    francistasset - Yanıt
  7. Use the attached pull tab to lift the hard drive out of the upper case.
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  8. Pull the hard drive cable away from the body of the hard drive. Remove the hard drive.
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
    The hard drive cable is a recalled part on these machines. You may need to replace it before your drive will be read correctly. The Apple Store will replace your cable for free if it's problematic.
    Eric March - Yanıt
  9. Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive. Transfer the hard drive retaining posts to your new hard drive.
    • Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive.
    • Transfer the hard drive retaining posts to your new hard drive.
    • If desired, transfer the pull tab over to your new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    • If you upgraded your EFI Firmware ROM you can also perform an internet recovery.
    T5, not T6 on mine.
    pilzn - Yanıt
    Reinserting the tiny screws was a pain, until I discovered this: initially turn them counterclockwise, till the threads 'agree' and the screw drops down into it's threded slot. Then go clockwise and they seat properly.
    Dave - Yanıt
    The paint on the screw threads makes it a little finicky to get them to 'find' the threading in their matching holes.
    Bad words were said, but job complete.
    Dave - Yanıt
    T6 were just too small to fit the screws of the retaining post, and T8 was just too big. I suspect a T7 will fit. I will get a T7 screwdriver and report back.
    Beware other users: T6 as the guide suggests may not be the correct choice for all.
    fludiumvatn - Yanıt
    I tries every T there is and eventually got a grip. But they just won't turnê. I evento tries using pliers but the screws stay unmovabble.
    Julio Lobato - Yanıt
    If replacing the hard drive with a 7mm SSD, is a spacer required? This guide from Crucial suggests it is, but there's no mention of it here.
    http://guides.crucial.com/Guide/MacBook+...
    Just wondering if people are managing without the spacer.
    Jeff Smith - Yanıt
    I had the spacer and used it, and all seems fine. I put in a Crucial MX500.
    Steve Jones -
    T6 perfect for me today.
    The screws came out easily for me, but I was not able to remove retaining posts from the old HD, so I just installed the new SSD without them.
    Koen van der Drift - Yanıt
    I just replaced the original hard drive on my mid 2012 MBP with a Crucial SSD from iFixit and am amazed at the new zip this has giving it! I first upgraded the RAM from 8 to 16 GB and that helped the speed but nothing like this new SSD, I found everything in this guide to be accurate for my computer. I did take the course of first cloning my original drive onto the SSD using the recommended SuperDuper! software, following the guide for that, and highly recommend taking that route.
    Great instructions as usual. Once I removed the old drive I found a round black rubber part (like a nipple) that had a rim on one end. I looked and googled to no avail! So there is a oblong hole (looks like a female lightning port) through the side of the MacBook right where the HDD is. And on the inside of the Mac there is a black frame near that oblong hole with a perfect circle shaped hole that this black rubber part fits into. All done and back together. Then I recalled person that I bought it from worked at auto dealer and took it into the shop where a co-worker used a blow gun to clean it up before selling. I guess 90 PSI blew the rubber part out!! So if any one finds one, you will know where to put it back
    CAM SEC - Yanıt
    The instructions are admirably clear and I successfully installed a 1TB Crucial SSD. However, it might be helpful to remark that the new drive MUST be formatted in APFS. Not knowing this, I formatted in HFS+ and loaded a Time Machine backup onto it. The new disk at first booted and then hung after the initial process had completed (the progress bar stayed on the screen). I only discovered the formatting problem when I wanted to clean install Mojave on the new HD. A day lost and a splitting headache later, everything is now up and running and LOTS faster!
    Christopher Clarke - Yanıt
    Dans le cas d’un replacement par un disque SSD, doit-on faire quelque chose pour le TRIM? L’activer ou pas? Si oui, comment doit-on procéder ?
    il semble que re-installer un OS à partir de Sierra cause beaucoup de problèmes, dans mon cas impossible d’installer Sierra ou High Sierra. Seul solution, cloner l’ancien disque avec l’utilitaire de disque.
    Franck - Yanıt
    Coner l’ancien DD sur le nouveau SSD avec : https://bombich.com/fr/kb/ccc5/everythin... .
    Pour Catalina prendre CCC5 (Logiciel gratuit).
    fbghosty - Yanıt
    Great instructions. The only and VERY important thing I would add is to copy your hard drive FIRST before you remove it. If someone above hadn’t mentioned this, I would’ve been screwed. (seems obvious now, but I’m a newbie with computer repair). I installed a Samsung V-nand SSD 860 EVO 500GB using the Sabrient 2.5 SATA hard drive USB 3.0 Enclosure with the Super Duper software. Took almost 6 hours to copy the HD. Then I just swapped it out with the old one. Voila! my 2011 MBP booted up perfectly! Thanks again for your help!
    FYI: I tried to order the Crucial SSD as recommended on this site; however, it never shipped from Amazon after over 2 weeks. The Amazon listing never said it was out of stock. So, I researched Crucial and discovered it’s been sold to China and the customer service/product isn’t what it used to be. I cancelled my order and just went to Best Buy. Do your own research.
    Christi Ruby - Yanıt
    another instance of T5 rather than T6
    wer - Yanıt
Sonuç
397 farklı kişi bu kılavuzu tamamladı.
34 Yorum
Under updated firmware, macbook pro unibody models will not recognize many third-party hard drives. See this discussion: https://discussions.apple.com/message/15...
Ewan Robinson - Yanıt
Awesome guide! Swapped my 320GB hard drive for an 1TB hard drive. Took five mins thanks to iFixit!
Chris - Yanıt
hey, do you use SATA 3 for you’re MacBook Pro A1278? is it work good? no problems?
dimdimisra -
dimdimisra, you use the built in cable that comes in it, because of the proprietary mortherboard connector, you can’t use a regular SATA 3 cable
ryan sparling -
I feel you should be pointing out a couple of things about the chassis screws that are not obvious to the inexperienced
- the 6 screws that are not along the hinge edge of the body (4 yellow & 2 of the orange) are not perpendicular to the flat surface; they go in at an angle such that their heads are flat in the curve in which they sit. Attempting to hold the screwdriver upright in these heads could lead to damage to the screws, stripping out the "cross"
- attempting to insert these screws "straight" when reassembling will lead to cross-threading and stripping the screw threads
Christopher Bedford - Yanıt
Will I notice a diference in booting speeds?
(actually, real question would be: Is it faster than the original sata, and if so, how much faster and how will it affect me?
C Eyzag - Yanıt
Yes almost 5 times faster 20s rather than 1min30s
Felix Roque -
I did this upgrade as instructed and everything went swimmingly. I used SuperDuper to clone the drive well before opening the mac and removing the original hard drive. I loved SuperDuper but there are also alternatives for cloning. The iFixit kit contains the proper tools too and it's a bargain though the drive can be had for much less elsewhere.
phreest - Yanıt
All went well. Entirely doable. I did the memory while I was in there too. So now have 16Gb and a 1TB SSD running! Couple of comments
1: Whoever suggested using a prescription pill day counter for screws was a genius. You should do that too. Telling the shouldered from the unsoldered 3.5mm Phillips 00 screws will drive you nuts otherwise
2: The recovery instructions are a bit old if you've been keeping you OSes up to date. If you have Yosemite or what not, you have had your firmware flashed. So just make a time machine backup on a USB drive; replace everything; and right after you power up, hold Apple-R (if you have WIFI) and it will boot. Use disk utility to partition the drive as bootable (macos journalled with guid), then plug in the USB time machine, and recover from that. Few hours later you are in business.
Thanks iFixit. Great instructions,
paul - Yanıt
I’m sorry, but I don’t understand Apple-r. Are you talking about the command key? I don’t have an apple on my keyboard. Thank you!
strofan23 -
I did this with the iFixit provided 1TB SSD. It all went well. It's really an easy task, though it might seem daunting. Just don't "force it" with any of the delicate parts.
The restart of the computer was a little startling. I flipped open the laptop and bam, it started. Might have been an errant press on the power button.
Also, to reinstall, I used "Internet recovery" which worked perfectly, as building a thumb drive boot drive failed on me. Internet recovery saved my world. Took about 4 hours to restore 320G of data on my new drive.
keimel - Yanıt
HI, i tried to swap my data from the old hard drive to the new one, but on my mac book pro the disk utility programm does not open...there is something called a Festplattendienstprogramm, but it looks completely differs than the utility program.
How can i find this program on my early 2011 MacBook Pro bought in germany?
Thanx for help!
Maike Wehmeier - Yanıt
I tried to swap my hard drive on a new 1TB one, but the disk utility program does not open! It seems, that it s not existing on this early 2011 MacBook Pro bought in germany. There is a "Festplattendienstprogramm" but it looks completely different and does not have the possibility to swap the data...Any idea how to solve this? Thanx for help!
I went to the apple store and they stated that I needed a new hard drive. But, they noticed a water mark that was marked red and said that it voided the warranty and I would have needed to pay even more for them to replace the hard drive. So I bought the hard drive suggested by ifixit and replaced the hard drive. When i start my computer it stay at a apple sign with spinning wheel for a while. I pressed command option R to try to download the mac ox software but the hard drive does not put up under the disk utility screen in order to download it. HELP!
ronald61 - Yanıt
try holding option, command, p and r on boot up. It’s called clearing the NVRAM I think (might be wrong about that ?) the mac soundeffect will play once then twice then let go. This really helped me out with my 2011 MBP after it installed some updates and didn’t seem to be able to load back up.
John Kuckens -
Excellent guide. My daughter's MacBook Pro had stopped booting up and when she took it to the local Apple Store they recommended replacing the drive. I took the opportunity to upgrade to the 1TB hybrid drive. Easy replacement. I booted up and reinstalled MacOS Lion via WiFi and then upgraded to Sierra. Everything is working fine and now have 900+GB of free space!! Thanks iFixIt folks
This guide, in combination with the youtube video instructions and the youtube video about how to clone the hard drive, worked perfectly. I am now using my much faster and much less full macbook - and loving it! Thanks for all you guys and gals do!
Melissa Smith - Yanıt
I used this guide to swap out my harddrive with an ssd. My Macbook pro is amazing now! Boot times and loading times are a thing of the past, and Spotlight searches are instantaneous! I won't need a new laptop for quite some time! The swap is easy, I did the whole thing in under 20 minutes.
Drew Dittmann - Yanıt
Anyone know how to do this with a hard drive that's already failed? I don't need to recover anything from it, I just need to get my daughter's 2011 Macbook Pro operational again. I don't think replacing the hard drive will be hard, what I don't understand is how do you get the Mac OS back on it?
Thanks
Troy Taylor - Yanıt
you can put a OS installer on a USB drive and after you install the new harddrive, hold command R and then follwo directions to boot from / install from USB.
John Kuckens -
Can i replaced using NVMe M.2 card instead? I notice that there is enclosure for sale to convert to SATA but not sure it will fit into the space or will it work, please advise. Thanks
dex tan - Yanıt
Superb - swapped out my late 2010 Macbook pro 500GB HD w/ a Seagate 2TB HSSD in 20 mins (sure, the Super Duper back-up took ~8hrs prior to) and it's off to the races, fast boot etc.! Brilliant DIY site, couldn't have made it any easier - thanks very much! James
James Brighten - Yanıt
dec tan - you can most likely use a NVMe M.2, but you won't get the actual speeds of an NVMe card, due to SATA limitations. You're better off just getting a regular SATA SSD for this computer.
Troy Taylor - You can use internet recovery (option-command-R) at boot up to reinstall the basic OS to a new hard disk.
john chinte - Yanıt
hi wich brand of hard drive should I get ? the hybrid or the ocz ? this will fit on early unibody and later ones ? thank you …
and this way more cheaper than the Samsung Evo’s
alex tiglao - Yanıt
I have an ealry 2011 MacBook Pro 13”. The computer just stopped working and I think the hard drive may need replacing since I dropped it and there is now a dent where the hard drive sits. I think I’ll replace it, but how do I get the operating system on it after replacing it? Some have suggested an OS Installer…not sure what that is. Please help! Thanks.
Mateo Hernandez - Yanıt
Having suffered significant damage, totally refurbished my MacBook Pro 13 early 2011 i7, I subsequently installed a Samsung 860 250 GB SSD. Following resetting NVRAM improved boot-up times.
Michael T - Yanıt
Just installed EVO850 500gb SSD on mac early 2011 with 16GB ram. No extra sata cable. Just replaced and started os x boot disk. All great. Amazing fast. Value for Money as Saves time :)
kabeer_bd - Yanıt
Hmmm could I replace the typical HDD with an SSD in a MacBook Pro Mid 2011?
Thanks,
Stephen McKenna - Yanıt
You probably did it already but yes you can. I did it a few days ago and it makes quite a difference, especially in booting.
tsa -
Well, that was easy. Thanks for the clear guide!
tsa - Yanıt
If you don’t already have the means to remotely connect your new hard drive to your computer, the hard drive/tool kit/hard drive enclosure is the way to go, as it gives you the option to clone your old drive to the new. Once that’s done, physically swapping-in the new drive allows you to seamlessly boot up from your new drive. The tool kit alone is easily worth the extra ten bucks, plus you get the USB hard drive docking station that you can use later with any SATA drive as an external drive (for backup?). Memory was upped at the same time, and it’s like I have a new computer!
Nathan - Yanıt
Perfekte Anleitung!
Hat alles super geklappt.
Zeitangabe ist sehr großzügig - mit etwas Erfahrung kann man das ist 10-15 Minuten erledigen.
500 GB SATA HD wurde durch eine 500GB SSD ausgetauscht. MacOS Catalina erkennt auch automatisch die SSD.
1A mit *
Z-City - Yanıt
Fantastic video and step-by-step instructions! Thanks SO much for this! I used your kit that included the hard drive and the tools needed which made things very straightfoward (MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle). The hardware installation was actually pretty easy, and I am NOT good at mechanical tasks, especially when the screws and tools are so tiny . The OS is installing right now! I am using Mac Internet Recovery.
My only (very) slight complaint is that I could not find anywhere that told me specifically if I needed the extra spacer that comes with the hard drive or not. The manufacturer, Crucial, should just have a list of laptops that require it and ones that don’t.
William Bell - Yanıt
ottima guida, ottimo risultato
grazie
davide artisan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 49
Son 7 gün: 305
Son 30 gün: 1,486
Her zaman: 629,246
