Ana içeriğe geç
MacBook Pro 13" Unibody Early 2011 Lower Case Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: adım 2, 2 resimden 1. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
Sonuç
60 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 36,400
