Ana içeriğe geç
MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement, Remove the lower case screws: adım 1, 1 resimden 1.
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement, Lift the lower case away: adım 2, 1 resimden 1.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement, Battery: adım 3, 1 resimden 1.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Using the flat end of a spudger, gently pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
    • Pry up from beneath the wires.
  5. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 5, 1 resimden 1.
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  6. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 6, 1 resimden 1.
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  7. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 7, 1 resimden 1.
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  8. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
    • The longer of the two screws is on the right.
  9. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 9, 2 resimden 1. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 9, 2 resimden 2.
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  10. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 10, 2 resimden 2.
    • Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case.
    • The right screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  11. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 11, 2 resimden 2.
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
  12. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: adım 12, 1 resimden 1.
    • Peel back the small piece of black tape covering the right speaker cable.
    • Be careful, as the power button ribbon cable is directly under this piece of tape.
  13. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 13, 1 resimden 1.
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
  14. MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker Replacement: adım 14, 1 resimden 1.
    • Lift the subwoofer and right speaker assembly out of the upper case.
Sonuç
43 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Thank you iFixit
Chamika Anuruddha - Yanıt
Thanks ifixit for the super guide. I followed the steps and now my mac works properly again!
Toni - Yanıt
Thank you iFixit!
I too snapped the right speaker/subwoofer cable connector right off the mother board, but with patience and a little research, I learned how to solder the thing back on. How about a Warning!!!!! inserted at that step.? I only saw that there were comments AFTER I gingerly tried to pry the connector as instructed. It would help to show how the parts fit together as is done with the fan cable connector. Those instructions (the fan cable connector instructions), helped me better understand what I was prying apart and gave me an idea of how best to do it, and how the speaker/subwoofer cable connector connected to the board, as well as how to position the “pads.”
So, I learned from my mistake, which is a good thing. Nonetheless, I would have preferred to learn BEFORE I snapped off the cable connector, LOL!
Thanks Again for this incredible site.
Leslie L. Gordon - Yanıt
My connection did not hold. I asked above what the best way is to solder or reattach the right speaker/subwoofer cable connector back onto the board. I saw the soldering guide, but have only soldered once. Any specific guidance on how to reattach this cable would be SO APPRECIATED, especially referencing the soldering guide. Visuals are extremely important to me.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 24
Son 30 gün: 83
Her zaman: 54,941
