Ana içeriğe geç
MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement
Neye ihtiyacın var
    1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Remove the lower case screws: adım 1, 1 resimden 1.
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Lift the lower case away: adım 2, 1 resimden 1.
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Battery: adım 3, 1 resimden 1.
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Display: adım 4, 1 resimden 1.
      • Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 5, 1 resimden 1.
      • Disconnect the camera cable by pulling the male end straight away from its socket.
      • Make sure to pull the connector parallel to the face of the logic board and toward the optical drive, not straight up from its socket.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 6, 1 resimden 1.
      • De-route the camera data cable from the channel in the optical drive.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 7, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 7, 2 resimden 2.
      • Remove the following screws:
      • Two 10 mm Phillips screws
      • One 3.8 mm Phillips screw
      • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 8, 3 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 8, 3 resimden 2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 8, 3 resimden 3.
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable connector straight away from its socket.
      • Make sure to pull the connector straight away and not straight up from its socket.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 9, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 9, 2 resimden 2.
      • Remove the following two screws securing the display data cable bracket to the upper case:
      • One 8.6 mm Phillips screw
      • One 5.6 mm Phillips screw
      • Lift the display data cable bracket out of the upper case.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 10, 1 resimden 1.
      • If present, remove the small strip of foam tape stuck to the display screws near the display data cable.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 11, 2 resimden 2.
      • Remove the two outer 6.5 mm T8 Torx screws securing each of the two display brackets to the upper case (4 screws total).
      FixBot'a Sor
      Yorum Ekle
    9. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 12, 1 resimden 1.
      • Open your MacBook so the display is perpendicular to the upper case.
      • Place your opened MacBook on a table as pictured.
      • While holding the display and upper case together with your left hand, remove the remaining 6.5 mm T8 Torx screw from the lower display bracket.
      FixBot'a Sor
      Yorum Ekle
    10. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 13, 1 resimden 1.
      • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
      • Remove the last remaining T8 Torx screw securing the display to the upper case.
      FixBot'a Sor
      Yorum Ekle
    11. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 14, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 14, 2 resimden 2.
      • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
      • Rotate the display slightly away from the upper case.
      FixBot'a Sor
      Yorum Ekle
    12. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 15, 1 resimden 1.
      • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Front Display Glass: adım 16, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement, Front Display Glass: adım 16, 2 resimden 2.
      • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
      • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
      • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
      • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 17, 3 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 17, 3 resimden 2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 17, 3 resimden 3.
      Bu adımda kullanılan alet:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
      • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
      • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
      • Slowly and gently pull the corner of the display glass up off the display assembly.
      • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 18, 3 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 18, 3 resimden 2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 18, 3 resimden 3.
      • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
      • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
      • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 19, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 19, 2 resimden 2.
      • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
      • Attach a suction cup along the right side of the front glass panel.
      • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
      • Continue working along the right edge of the front display glass until it is separated from the display.
      • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 20, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 20, 2 resimden 2.
      • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
      • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
      • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 21, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 21, 2 resimden 2.
      • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
      • Attach a suction cup near the upper left corner of the glass display panel.
      • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
      • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 22, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 22, 2 resimden 2.
      • Use a heat gun or hair dryer to soften the adhesive under the black strip along the left side of the front glass panel.
      • Attach a suction cup along the left side of the front glass panel.
      • Continue working along the left edge of the front display glass until it is separated from the display.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 23, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 23, 2 resimden 2.
      • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
      • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
      • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
      FixBot'a Sor
      Yorum Ekle
    9. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 24, 2 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 24, 2 resimden 2.
      • Skip this step if you're reusing the original glass.
      • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
      • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
      FixBot'a Sor
      Yorum Ekle
    10. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 25, 3 resimden 1. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 25, 3 resimden 2. MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement: adım 25, 3 resimden 3.
      • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
      • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
      • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
      • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
      • Reapply the piece of tape covering the camera cable socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
70 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
If the glass you are replacing is badly broken the suction cups may not attach. I ended up having to remove the glass piece by piece and the process took a couple of hours. You should wear protective glasses and wear rubber gloves to prevent getting finger prints on the lcd screen. Although this was a time consuming process I was successful removing the broken glass and replacing without any issues.
davidstewart - Yanıt Paylaş
I actually had the same problem as David but in 2 hrs I had removed all of the glass pieces. Now my MB looks like it had never fallen!
Thanks ifixit, you saved me €450.
PS. the parts were in Belgium in 3.5 days, I was amazed at how fast it was.
matthiasvanaverbeke - Yanıt Paylaş
I found it more convenient to lay the computer keyboard-down on a table with the display hanging over the edge while performing steps 11–15.
David Kilbridge - Yanıt Paylaş
The need for a hot air gun greatly increases the possibility of damaging various parts of the laptop [keyboard, airport antenna assembly, clutch cover, strip around the screen, even the screen, possibly the two brackets --- which allow the top and bottom cases to fold together for the clamshell effect --- which are not metal but rather plastic painted to look like metal]. Some people have spent the extra money to buy a special hot air gun with a small focused spout. But, the smarter, simpler, approach is to forget about replacing just the front glass cover and replace the entire display assembly instead. iFixIt is currently out of stock of entire display assemblies, but you can find them elsewhere on the Net for $100 or less. Instead of buying iFixIt's glass cover and recommended tools, I could have bought the entire display assembly for about the same money.
istlota - Yanıt Paylaş
Hello, what kind of glue should I use to fix the new new glass on?
kekko690 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 70
Her zaman: 119,606
