Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace a cracked front display glass panel.
Neye ihtiyacın var
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
Attach a suction cup along the right side of the front glass panel.
Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
Continue working along the right edge of the front display glass until it is separated from the display.
Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
Attach a suction cup near the upper left corner of the glass display panel.
Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
Use a heat gun or hair dryer to soften the adhesive under the black strip along the left side of the front glass panel.
Attach a suction cup along the left side of the front glass panel.
Continue working along the left edge of the front display glass until it is separated from the display.
To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
70 farklı kişi bu kılavuzu tamamladı.
7 Yorum
If the glass you are replacing is badly broken the suction cups may not attach. I ended up having to remove the glass piece by piece and the process took a couple of hours. You should wear protective glasses and wear rubber gloves to prevent getting finger prints on the lcd screen. Although this was a time consuming process I was successful removing the broken glass and replacing without any issues.
I actually had the same problem as David but in 2 hrs I had removed all of the glass pieces. Now my MB looks like it had never fallen!
Thanks ifixit, you saved me €450.
PS. the parts were in Belgium in 3.5 days, I was amazed at how fast it was.
I found it more convenient to lay the computer keyboard-down on a table with the display hanging over the edge while performing steps 11–15.
The need for a hot air gun greatly increases the possibility of damaging various parts of the laptop [keyboard, airport antenna assembly, clutch cover, strip around the screen, even the screen, possibly the two brackets --- which allow the top and bottom cases to fold together for the clamshell effect --- which are not metal but rather plastic painted to look like metal]. Some people have spent the extra money to buy a special hot air gun with a small focused spout. But, the smarter, simpler, approach is to forget about replacing just the front glass cover and replace the entire display assembly instead. iFixIt is currently out of stock of entire display assemblies, but you can find them elsewhere on the Net for $100 or less. Instead of buying iFixIt's glass cover and recommended tools, I could have bought the entire display assembly for about the same money.
