Giriş
Use this guide to replace your hard drive cable. A new hard drive cable also provides a new IR sensor.
Aletler
Parçalar
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two Phillips screws securing the hard drive bracket to the upper case.
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
Two 1.5 mm Phillips screws.
Two 9.5 mm Phillips screws.
198 başka kişi bu kılavuzu tamamladı.
17 Yorum
This is a useful guide as usual, but I think ifixit might slitly change it, and give a little picture to show how to remove the bracket from the cable :)
This is exactly what I wanted to see and they didn’t have it :( but it worked out okay in the end!
Pretty straight forward guide - follow other user's directions for replacing the IR receiver (if you didn't purchase a new one). Fairly easy as well.
Only complication I had was with extremely tight screws, which with screwdriver heads with tighter fits becomes a non-problem immediately.
Didn't realize this was such a prevailing problem as the issues with my HDD were fairly obscure/didn't follow some of the general problems that other users online were encountering.
Fantiastic!!
I had an SSD installed but it stopped working after a few months and I got the flashing question mark folder. It was very odd as the disk drive still worked, and the SSD did externally. Heard it could be the SATA as SSDs are more sensitive to damaged cables, so replaced it on the off chance and it worked! Definitely recommend trying this first if you have had the same problem
Wow, this worked so GOOD! ...and those derps at the local Apple retailer told me to "let the computer go, and take a look at the new ones we have here!"
Did troubleshooting with ifixit, ordered part from ifixit and followed step-by-step guide provided by ifixit! You guys rule!
Many thanks from Sweden!
