Ana içeriğe geç
MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
Neye ihtiyacın var
  1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 2, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement, Battery Connection: adım 3, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement, Battery Connection: adım 3, 2 resimden 2.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 4, 1 resimden 1.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Assembly: adım 5, 1 resimden 1.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  6. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 6, 1 resimden 1.
    • Carefully pull the camera cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
  7. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 7, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 7, 2 resimden 2.
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  8. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 8, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 8, 2 resimden 2.
    • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
    • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  9. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 9, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 9, 2 resimden 2.
    • Using the method described in the last step, disconnect the remaining three antenna connectors.
    • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
  10. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 10, 1 resimden 1.
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  11. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 11, 1 resimden 1.
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  12. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 12, 1 resimden 1.
    • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
  13. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: adım 13, 1 resimden 1.
    • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
  14. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 14, 2 resimden 1. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 14, 2 resimden 2.
    • Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
    • Remove the AirPort/Bluetooth cable.
  15. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 15, 1 resimden 1.
    • Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
  16. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 16, 1 resimden 1.
    • Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
  17. MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement: adım 17, 1 resimden 1.
    • Remove the AirPort/Bluetooth board from its bracket.
    • Be careful not to damage the pink thermal pad attached to the bracket.
Sonuç
92 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
512.205 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.608 adet Kılavuz yazıldı
14Kılavuz Yorumları
Just to say if you only need to replace the cable the from the main logic to the Airport card it is very simple after battery disconnect its just pry up logic board connector carefully then peel back tape at airport card and remove cable.
Thats all there is to the cable replacement and it fixed my No wifi hardware found and intermittent wifi which it would seem is a common fault As always a great guide thank you.
Keith - Yanıt
Thanks for the tip Keith. I did the cable replacement too based on your comment, and it worked for me. Worth trying before swapping teh whole assembly.
Karl Price -
My macbook pro 13 2014 version wifi screen holder and the wifi card bluetooth cables are broken , so i went to repair it by my self and i bought the wrong full screen and the wifi card back to macbook pro 13 2010 version , it was shock so i would to know Can i change the wifi card cables and the screen adopted cable to the new cables of 2014 macbook pro 13 2014 version?
ahat2013 - Yanıt
what's the difference between the normal "phillips screws" and the "shouldered phillips screws"?
Daniel Rathlef - Yanıt
If you look closely with the screws (my eyes needed a magnifying glass) you will see that some of them have heads that are "stepped". hard to describe in words.
perasso -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 123
Son 30 gün: 562
Her zaman: 117,544
