Giriş
Use this guide to replace a broken display assembly.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
207 farklı kişi bu kılavuzu tamamladı.
36 Yorum
No the connector in the logic board/video cable is slightly different.
I have a mid 2012 13" Macbook pro. This is a non retina computer but would it be possible to change it to a Retina Display using this guide and would my Mac recognize the new screen?
(I have plenty of memory and the graphic card can definitely handle it too)
Thanks
I doubt it would work, But be my guest to try it. (and post a guide on how to do it)
