Ana içeriğe geç
Giriş
Are the gobs of OEM thermal paste causing your MacBook Pro to be sluggish while hot? Use this guide to remove your heat sink and apply new thermal paste.
  1. Remove the following ten screws:
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
    How much weight can I save by removing the optical drive?
    gunes314 - Yanıt
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - Yanıt
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - Yanıt
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - Yanıt
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - Yanıt
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - Yanıt
    I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
    cam2000deluxe -
  2. Use your fingers to pry the lower case away from the body of the MacBook near the vent. Remove the lower case.
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board. It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    Is this step of removing the battery connector required?
    manodh - Yanıt
    yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
    khull -
    Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
    aekinaka - Yanıt
    Be patient on disconnecting this one. It worked for me step by step, little by little.
    Phil Wagner - Yanıt
  4. Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    I put some tape between the connector and socket while working on the drive.
    Stephen Smith - Yanıt
    That's a good tip
    Anrothan -
    Great tip, I did that too
    Ahmed Mahran -
    One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
    lelandjordon - Yanıt
    On my MacBook Pro, the connector seems to be an integral part of the battery.
    Jerry South - Yanıt
  5. Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    I successfully soldered the fan connector back on for a friend. I used a small soldering iron (maybe 6-10 watts) and ground the tip down to a very fine point. Also used a magnifying light and very fine rosin core solder. I took my time and lined everything up and was careful not to heat any other junction unnecessarily.
    Scott Stanley - Yanıt
    Yup. Be careful on this one. I was trying to gently pry up and popped it off the socket. Computer working fine after replacing magsafe board, but no fan for cooling…
    Thomas Carr - Yanıt
    This one is really delicate, as pointed out.  Be careful if using the pointed end of a spudger NOT to dig down and under ….there’s a layer of plastic-y insulation that can be torn.  I accidentally gored it with the pointy end of a spudger and it was slightly ripped.  Fortunately, I was able to press it down and there was no problem when the cable was reinserted.
    Carolyn Ryan - Yanıt
    For less than $16 I ordered a new fan from amazon. Fans eventually start making noise. If they fail, your system could expire from heat. Consider simply replacing your fan since this model is now about five years old. Here’s link:
    https://www.amazon.com/gp/product/B00FWP...
    airshack - Yanıt
    I used a guitar pick and gently wiggled underneath to lift it up and out of the socket. no damage! woo hoo! on to step 7!
    jcundy2 - Yanıt
    I simply skipped this step and left fan wire connected to logic board. Just unscrew screws from Step 6, put fan on the logic board and remove whole stuff togheter.
    paczor - Yanıt
    Thanks, I did that too,,
    a lot easier
    Ahmed Mahran -
    Yes, tricky. Insert the spudger just like in the photo. You won’t be able to dig it out out from any other side. Also, notice which side of the connector faces down into the socket: it is the side without the four shiny gold areas (again, just like in the photo).
    rmccord23 - Yanıt
  6. Remove the following three screws securing the fan to the logic board:
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
    These are T5 screws
    dbell316 - Yanıt
    I think so too, (maybe on a certain batch?) tried a T6 and its too big
    billytalentlovexo -
    I wasn’t able to open mine up. The heads looked like little triangles instead of hex torqx things. Is there a chart with the head shape of all the bits you can buy? I want to just get the one.
    Christopher Roode - Yanıt
    They might be tri point
    Daniele Carminati -
    they were T6 for me
    lamajr - Yanıt
  7. Lift the fan out of its recess in the logic board, minding its cable that may get caught.
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
  8. Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case. Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
    Reminder: When replacing the cable the connector should be placed in from above. This fooled me and I damaged the seat a bit, but not enough to prevent proper connection.
    Lee Hughart - Yanıt
    Excellent guide, I feel this bit could be clearer tho. As it is a socket like a fan connector.
    Mine had a foam pad on the top like the other lift-up connections and I’ve accidentally taken the socket off.
    So just to be aware if your mac has the foam pad on top of this connection.
    acupton86 - Yanıt
  9. Disconnect the camera cable from the logic board.
    • Disconnect the camera cable from the logic board.
    • Pull the cable parallel to the face of the logic board. Pulling the cable upward may damage the logic board or the cable itself.
    The camera cable head has bump at both sides. Just use two spudgers to pry it out.
    townbull - Yanıt
    thank you great suggestion
    Soham Thacker -
    Here's where the mid-2009 13" MacBook Pro 5,5 makes its first major departure from this guide. No such connection exists. At least nowhere I could find on the motherboard.
    Larry Horton - Yanıt
    IIRC the official service manual suggests putting the blunt or wide edge of a black-stick/spudger underneath the cable and then pressing down on said cable to provide better gripping force while pulling the cable out/away from the connector. It’s my tried-and-true method of choice.
    James - Yanıt
    Anyone has a data of this cable becausei brkoe it and i have an other same connector ??
    Mail : mr.leminecrafteur@gmail.com
    VARE - Yanıt
    Just broke this cable by pulling to hard. Definitely use a spudger to pry out the connector instead of pulling the cable.
    maxpoetter - Yanıt
    Same, any suggestion about its replacement?
    giovanni.billet - Yanıt
    Really grip those little bumps on the head with a pair of pliers and gently wiggle!
    moonsugar33 - Yanıt
    In case you need replacement parts for the broken cable : http://www.powerbookmedic.com/MacBook-Pr...
    To find out how to replace the cable, you can have a look at this tutorial : https://fr.ifixit.com/Tutoriel/Remplacem...
    Guillaume Lamaison - Yanıt
    Die Metallverbindung besteht aus zwei Teilen. Der kabelferne Teil drückt den Stecker nach unten. Der kabelferne Teil ist ein festgelöteter Schuh. Mit Hilfe einer dünnen Präpariernadel konnte ich den kabelzugewandten, beweglichen Metall-Teil der Verbindung zum einen horizontal herausschieben, zum anderen habe ich gleichzeitig gezogen. Nicht zu viel Kraft beim Ziehen aufwenden.
    Mir hat geholfen, ein Makrofoto vom Stecker zu machen, um ihn zu verstehen.
    hpw - Yanıt
  10. Disconnect the following four cables: AirPort/Bluetooth cable
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
    On the mid-2009 13" MacBook Pro 5,5 the Airport/Bluetooth cable is different from the other three cables in this step. It's fabric wrapped, and its connection works in a fashion more like the display data cable connection, although it does not have a lock that releases by pulling a tab back over the cable. So, to those of you who are repairing this model, be careful. Prying upward is not the way to remove this cable. I played with it until I could detect which parts were moving which way and why. Although I can't say with precision how the connection works, I removed it by gently coaxing slightly up at an angle and back along the plane of the optical drive. The idea is to pull the cable back out of its socket while lifting slightly.
    Too bad we can't post photos in the comments.
    Same with the Mid 2010 model - moving the cable parallel to the board, towards the optical device works fine.
    Hans - Yanıt
    It is advised to tape all those connectors out of the way of the mainboard. Use paper tape or paper labels as you want to avoid the electrical discharge associated with peeling off of plastic tape.
    dbovey - Yanıt
  11. Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
    Hello i've a late 2011 and have manged to break the keyboard ribbon cable ZIF socket. Is this a part that can be replaced? Ribbon is still good just the plastic has broken on the edge. Thanks
    Derek Cowan - Yanıt
    No, You'll need to replace the logic board. I'd probably just use a wired or bluetooth keyboard and put the money towards a new machine.
    maccentric -
    I ran into trouble reattaching the keyboard ribbon cable into the ZIF socket. I couldn't grasp it in a way that let me push it all the all back. A local repair guy told me his trick: use a piece of tape. Attach a piece of tape to the ribbon cable and make a tab so you can pull the cable into the socket. Use of a piece of tape that you can easily remove. Works like a charm.
    David - Yanıt
    Buy that man a pint! I've been working on computers professionally for a decade and I've never thought of that trick. Brilliant!
    Gryyphyn -
    Amazing this saved me!
    Felipe Cordero -
    You've saved me countless hours of crying trying to simply push it in
    Tunipguy -
    Thanks! This saved me hours!
    Marc Steffen -
    Thank you so much. Very clever idea that works like a charm!
    Todd Walls -
    Thank you so much! After 15 minutes of frustration, it inserted in less than 5 seconds.
    Todd Walls -
    After I put it all back together, the keyboard didn’t work; I traced it to this cable not being plugged in all the way. I used the tape trick to coax it all the way in to seat well and it works like a charm.
    Ruedi Schubarth - Yanıt
    Thanks for the tip about keyboard ribbon, saved me a major headache
    domhnallk - Yanıt
    It’s worth pointing out that the lever to lift this is at the back of the connector and that you’re pulling it towards yourself - this then releases the plastic on top of the cable that’s holding it in place.
    Nick Watts - Yanıt
    The tape tirck saved my bacon!! Thank YOU!
    Jonathan Davis - Yanıt
    Thanks so much. This trick saved the day!!!!
    Rafael Giuliano - Yanıt
    It is advised to tape this connectors out of the way of the mainboard. Use paper tape or paper labels as you want to avoid the electrical discharge associated with peeling off of plastic tape.
    dbovey - Yanıt
    Der Sicherungsbügel kann leicht mit dem Fingernagel vom Mainboard um 90 Grad zu mir her geklappt werden. ACHTUNG: Genau lesen, filigrane Teile gehen leicht kaputt.
    hpw - Yanıt
  12. If present, remove the small strip of black tape covering the keyboard backlight cable socket.
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
    The bottom of the small strip has excellent adhesive which will re-stick upon reassembly without any problems. I handled the sticky side and even stuck it to a plastic tray without any issues. Which is to say the sticky-ness does not seem to wear off.
    airshack - Yanıt
    This is the most difficult ribbon cable to reinsert. As noted in the comments for the keyboard ribbon cable above I’d recommend also using a a small piece of tape to help reinsert.
    Bill Kirby - Yanıt
    I used Blu-Tac on the end of my spudger to provide a gentle grip to get it to slide in.
    moonsugar33 - Yanıt
    dbovey - Yanıt
  13. Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Pull the keyboard backlight ribbon cable out of its socket.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
    The first time I reassembled the system I left this tiny ribbon connector under the logic board by accident. If your keyboard backlight no longer works after reassembly it’s because you forgot to reattach this small connector. Fortunately, I caught my mistake before securing the logic board screws. It’s an easy to miss item.
    airshack - Yanıt
    dbovey - Yanıt
  14. Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
    the sleep sensor/battery indicator were not included with my new case, i had to transfer them over from my old case. once the battery is out (step 22), you can see the three screws you need to remove in order to take it out. it’s also secured by adhesive. the button for the battery indicator will likely fall out (at least it did on mine) when you remove the board, so be careful not to lose it…my new case did come with the button for the battery indicator (even though it didn’t come with the board or cable), but i just re-used the old one.
    Matt - Yanıt
    I forgot to place this tiny flex cable on top of the mainboard, and tried to recover it from under (lazy!) so I broke it.
    In general I would tape all those connectors out of the way of the mainboard. Use paper tape or paper labels as you want to avoid the electrical discharge associated with peeling off of plastic tape.
    dbovey - Yanıt
    Update: the computer works even without this feature. Of course the led battery indicator does not work, but it is not a big loss.
    dbovey - Yanıt
  15. Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board. Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Its quite delicate, pull gently and it will pop out with a slight clicking sound
    Leo Jose - Yanıt
    On my mid-2009 13" MacBook Pro 5,5 the display data cable was square with the motherboard, rather than at an angle. I'm not experienced with working on computer connections, but if I were going to describe this procedure, it would be more like:
    "Grasp the plastic tab on the end of the display data cable connection, and pull it gently back over the cable, toward the DC-in board. The tab is connected to a flat rectangular 'ring' that locks the cable to its connection, and when you pull the tab, the rectangular lock will flip back over the cable, allowing the cable to be removed by pulling the same direction, parallel to the surface of the motherboard."
    Exactly the same as on the Mid2010 Model - never pull up, always parallel to the board, using the spudger to keep the cable down might helpfull while pulling with fingers the cable towards DC-In at the right side.
    Hans -
    My display is not working after reassemble the mac.
    Any reason?
    Nitin Sonwal - Yanıt
    I had the same problem, and it was solved by slightly unscrewing the 14.4 mm screw that sits nearest the ESC button (upper left hand side, if the computer is open as if you’re using it). All the way screwed in, and the display conks out (something must be getting pinched). Slightly loosened, and the display immediately came back!
    Shannon Maguire -
    I choose not to remove this, just laid the board over. Worked just fine.
    Justin Patterson - Yanıt
    I second this. It’s quite easy to leave this connection in place. The board flips over nicely, and everything is still accessible.
    Steven Weeks -
    I used my phone to photograph the entire underside of the Macbook Pro before I started removing things. This photo helped augment the excellent photos here. Take a few close-ups of each section/item before disassembly to reference upon assembly.
    airshack - Yanıt
    when reattaching the display cable, i used the spudger to tuck the spongy top flap underneath the cable lock, so that i could then get the cable lock down the entire way. i couldn’t get it under there (and get the lock closed) without it, the top part of the display cable blocked it.
    Matt - Yanıt
    When replaced the logic board when reassembled lap top screens not working. Saw others similar issues plugged in my monitor it’s working great must have messed up any ideas how to fix?
    Wayne McCarthy - Yanıt
    Hi Wayne, and Michael! I had the same problem, and it was solved by slightly unscrewing the 14.4 mm screw that sits nearest the ESC button (upper left hand side, if the computer is open as if you’re using it). All the way screwed in, and the display conks out (something must be getting pinched). Slightly loosened, and the display immediately came back! —Shannon
    Shannon Maguire -
    My display is not working after I put everything back together, can hear the macbook chime. Tried shining light onto the display, see nothing. Tried loosening the screw slightly like someone suggested here, that does not help either. Tried cleaning the contacts of the LVDS cable, nothing. Any help appreciated.
    Don Seenu - Yanıt
  16. Remove the following nine screws:
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
    2 of the 7 listed 4mm screws attaching the logic board are actually 4.5 or 5 mm.... unfortunately. I didn't notice that until I was reassembling. so I don't know which positions they came from.
    starf1970 - Yanıt
    I'm just noticing this too... I've put the longer screws as the two on the far left of the picture because they seemed to be the two holes I couldn't see the bottom to.
    ForumHermit -
    Just took one apart and paid attention this time. On this Mac, the screws colored orange should be red, and the 2 screws on the left side of the board should be orange (they’re a bit longer).
    maccentric -
    For keeping the screws straight I drew a simple diagram and placed them on it head down/threads up in their respective positions. Then all screws went back into their original positions without any guess work. Another suggestion I have during assembly is to start the screws without torquing them all the way down - leave them a little loose to allow some adjustment of the logic board for getting them all to line up with their holes, then torque them down. This technique also works for the screws on the bottom cover/lower case.
    Great guide! Saved me some dough, and now my MagSafe connector stays nice and cool.
    gregory mogle - Yanıt
    for me the two on the farthest left were the 4.3mm screws. otherwise all went as described
    Levi Hoover - Yanıt
    on something like this (like in iphones) i print the picture and place the screws on the picture. saves some problems and guessing.
    jeff chasalow - Yanıt
    Well on my mid 2012 MacBook Pro the screw heads are definitely not T6 but rather J000. Will place the removed screws on a paper drawing of logic board. Good tip ….
    dontrep7a3 - Yanıt
  17. Remove the following two screws: One 8.6 mm Phillips screw
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
    Definitely not necessary to remove this bracket. You can disconnect the mic from the logic board and not have to deal with this bracket.
    kc7gnm77 - Yanıt
  18. Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
    Careful with this one. The wires are very thin fragile and it’s glued down very well making it extremely hard to remove. Just go slow and be patient otherwise you’ll damage the wires.
    Rob Kruit - Yanıt
    I finally got that mic out by gripping it between two spudgers like a pair of chopsticks and gently pulling it out at an angle. The rubber shroud on it makes the thing hard to grip, and when I finally pulled it free, part of the adhesive ring tore off and stayed stuck to the chassis. When reassembling the machine, I had to kind of squish it back into place. It doesn’t hold quite as well as it did before, but it seems fine.
    Thomas - Yanıt
    I managed to get the board out without prying the microphone off by twisting the board out while the microphone is still connected.
    You can then disconnect the microphone cable, which is a similar style connector to the fan cable and remove the board completely
    Alex - Yanıt
    Vraiment pénible cette déconnection, allez y gentiment et la colle partira.
    raph raph - Yanıt
    when reseating the logic board, first install the DC board in position and loosely seat the screws. then try to align the logic board to the 3.6mm screw housing closest to the firewire/ thunderbolt port and align the board to the ports and gently drop it into position. watch out for the cables that can get snagged under the board while seating it.
    Avocet Peregrine - Yanıt
  19. Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
    I had the same issue. After wiggling the logic board back and forth and slowly applying more force, just up the threshold where I felt uncomfortable, it came out. The problem appeared to be caused by glue on the heatsink barcode sticking to the layer underneath.
    Shaun - Yanıt
    I did all this, and worked! .but Im wondering, has anybody unscrewed what seems to be a mini heatsink (black 1 inch square housing) on the integrated GPU? Could I re apply paste on that?
    tony perry - Yanıt
    I did make the change yesterday. inside it has a thermal pad, that appears to be 3mm or less. i try to clean on my best. I make a making a very tick pea size and added again. but i have no idea if it works or not. still having temps on 56c on idle. there is no much info on that. i use MX-4 from arctic. but i still, in my option, a little to for my use. if someone have more info on that part on the late 2011 i7 macbook pro 13inch please send the info.
    Carlos De Bernard -
    I did and applied Arctic Silver 5 underneath instead of the crap tape they put under there. This alone stopped the random freezing and rebooting problem I was having with this macbook pro. I recommend if you're already that deep into it, you might as well do it. I'm glad I did.
    ej257lgt -
    Need help. After I put everything back together, everything works fine but my macbook just wont charge. Any diagnosis on this? Anyone who can explain to me how the battery and the charging work in a Mac?
    justfinditjoshyip - Yanıt
    If this happened to me, I would first suspect I hadn't completely connected the DC-in board cable. If I hadn't just replaced the battery, I would wonder if the battery was good. MagSafe power cable connect connections fail too, especially if they've been attached for a long time to a red hot DC-in board.
    If those failed, I'd head to the genius bar!
    Larry Horton -
    I had this problem. I accidentally cut the a cable from the DC-in board and I had to buy this component and replace it. You have to be very careful when mounting back the logic board in its position to not get a cable from the DC-in board cut by the screws.
    Enrique Cerrillo Cuenca -
    I broke the black backlight shield.... be careful when you feel the logic board and the film underneath it seem stickinig togethre.
    EUNAE JO - Yanıt
    The fan exhaust grille was catching onto the speaker unit so I had to skip to step 28 to take it out. After taking out the airport card the speaker was able to move away from the fan grille and let me lift out the logic board.
    Antonio Cabrara (MrUnkownGuy) - Yanıt
    Also be sure to lift up the logic board to a slight angle so it clears the optical drive then pull it out gently at that angle. Do not pull it ulwards.
    The mainboard got stuck with the speaker and I can't lift it up. So I removed the first speaker screw (Wich is nearest to the mainboard) then I was able to remove the mainboard
    Mauricio Larrea - Yanıt
    I removed the battery …. helps getting the logic board out.
    dontrep7a3 - Yanıt
  20. Remove the three 8.4 mm #1 Phillips screws securing the heat sink to the logic board.
    • Remove the three 8.4 mm #1 Phillips screws securing the heat sink to the logic board.
    • Don't lose the springs held under each of the screws.
  21. Carefully remove the heat sink from the processor.
    • Carefully remove the heat sink from the processor.
    • If the heat sink seems to be stuck, it may be helpful to gently pry it off the processor with a plastic spudger. Be careful not to break any surface mount components on the processor while prying.
    • Be sure to clean off the old thermal paste and apply a new layer before you reinstall the heat sink. We have a guide that makes it easy.
    Probably most people are here because of overheating problems and they want to replace the thermal paste. Use a decent thermal paste that lasts. Arctic Silver 5 doesn’t dry out as it’s based on silver particles.
    Rob Kruit - Yanıt
Sonuç
117 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
474.529 İtibar
410 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
138 Üyeler
16.493 adet Kılavuz yazıldı
8 Yorum
Thanks, you’re a lifesaver! It’s much easier than I imagined. Used this to replace the old thermal past with some Arctic Silver 5. Temperature differences are surprising. During the break in period it went from 60 degrees Celsius idle to 50 degrees and from max 105 degrees Celsius under heavy load to about max 90 degrees. Now after a 24 hour break-in period it went down to 45 degrees idle and 85 max under heavy load. Will update if there’s any changes after the full 200 hour break-in period specified by the manufacturer.
Rob Kruit - Yanıt
Reporting back. Temperatures now @ 41 degrees Celsius idle and under full load between 81 and 85 degrees. System is stable again like before. This really solved a lot of problems for me!
Rob Kruit - Yanıt
Seems I’m facing with same issue. I’m testing temperature with “Intel Power Gadget“ application. Idle temperature is about 65-70 degree and during high load is about 100. Hope changing old thermal past will help me.
dmitrybalabka - Yanıt
After I have changed the thermal paste now it is possible to see 100% process utilisation and stable 3.4 GHz usage (Macbook Pro 2012 Mid i7). I’m still getting 100 degrees but seems it is ok now. To see the difference I suggest to check “Intel Power Gadget” application charts before and after thermal paste change. I did not run any special benchmarks just run some heavy task which utilise all cores (e.g. IDE code indexing)
Andrew, thanks a lot for this guide!! In my machine the fan was spinning a whole lot, even with a load of only 10%. After replacing the thermal paste the machine is now completely quiet. Thanks again for this great and detailed instruction, I appreciate it.
Oliver - Yanıt
Hello I wonder if this still gets replies. But after following the method and putting the parts back together. When I tried to plug my charger, no light showed up and a couple of seconds later, it started to blink orange and it wouldn’t charge battery. Please help me with solutions and thank you.
Jacob Lopez - Yanıt
I fixed my problem. I bought a new MagSafe Module on ifixit-store and applied it. It seems like I damaged the old one with some kind of static after all.
I used a anti-static mat and wristband, just to be sure. So for anyone who has the same problem: Just invest, like, 30 dollars into a new MagSafe Module. There is also a great guide available here.
Max B. - Yanıt
The process was really easy except that the MBP didn’t boot at the first shot. The keyboard ribbon was not inserted properly and in order to install it correctly I followed another advice on ifixit: I helped my self with a piece of adhesive tape with which I applied quite some horizontal force on the ribbon/socket couple. At the end everything went super smoothly. It took me about 40’ total and I have gained more that 10*C on idle. The machine feels brand new, it runs cold and it is super snappy again. Almost at its 10th birthday!!
davidmunao - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 187
Son 30 gün: 975
Her zaman: 78,634
